7I76E doesn't read inputs
5 years 7 months ago #201127 by lawley
Having previously used 7i77 Mesa cards on a number of projects, I purchase a7i76e to use on a gantry router, I cannot get any of the inputs to read, W1 is in the left hand position. It also does not output any voltage to the outputs. There appears to be comms to the card as Axis happily boots. 5v is supplied to P3. 24v is supplied to TB1 pin 1+ and Pin 8-
Any help would be appreciated
Brian
5 years 7 months ago #201129 by PCW
Replied by PCW on topic 7I76E doesn't read inputs
The 7I76E field I/O is basically identical to the 7I77s field I/O
Have you use the "watch" function to look at the input pin status?
If you have 24V power you need to connect the field inputs to +24V to read high
5 years 7 months ago #201131 by lawley
Replied by lawley on topic 7I76E doesn't read inputs
I am taking the input to +24V. I was using Hal Meter to monitor the input. Nothing shows there. When I select Flood coolant, Hal meter shows the output as True but the card does not output 24V at that output. Can it be a firmware issue.
5 years 7 months ago #201132 by PCW
That cannot really be a firmware issue
If you start linuxCNC from the command line, are there any errors reported?
5 years 7 months ago #201172 by lawley
Many thanks for your assistance, I managed to mix up TB 5 and TB 6. W8 was missing from my board.
Time to create page: 0.302 seconds
