No stepper movement
5 years 7 months ago #201794
by 9183jim
Replied by 9183jim on topic No stepper movement
Hi i have tried to modify existing and deleting and dunny setups and in the tried to do a setup in the hal.
Even reloaded linux to see if that was the problem more than once and different releases
5 years 7 months ago #201798
Replied by andypugh on topic No stepper movement
Can you attach the HAL and INI files?
What is your parallel port address?
5 years 7 months ago #202166
by 9183jim
Hi
Please find attached the files and this as follows is the address of the parports according to my terminal
jim@Debian:~$ sudo cat /proc/ioports | grep parport
[sudo] password for jim:
e010-e012 : parport0
e013-e017 : parport0
jim@Debian:~$ lspci -v
bash: lspci: command not found
5 years 7 months ago - 5 years 7 months ago #202169
In the HAL file, line 6 says:
I think that this needs either the address, or the index.
loadrt hal_parport cfg=" out"
loadrt hal_parport cfg="0 out"
or
loadrt hal_parport cfg="0xe010 out"
Last edit: 5 years 7 months ago by andypugh.
5 years 7 months ago #202184
by 9183jim
Hi thanks for you help to date. I have tried different combinations and the ones you suggested and moved the card to a different slot. I have measured the voltage out of the bob and am not getting a feading at the pull - and direction - not sure if this is correct or not. I will try a different computer and cable next week to at least discount the computer or cable as the problem. I will let you know the outcome
5 years 7 months ago #202526
Have you measured the voltage _in_ to the BoB?
(Note that you can probably only see the DIR pin with a mutlimeter, on either side)
Time to create page: 0.189 seconds
