hello all, beginner here with some issues with linux cnc
5 years 7 months ago #202481 by newbynobi
@Aciera,
thanks for your attention, I must have overlooked that one. Your solution should solve the problem.
Norbert
The following user(s) said Thank You: santiagoe
5 years 7 months ago #202505 by santiagoe
hi thanks for your answer, with that i was able to get the led and feedback bar working in gmoccapy also i commented the pyvcp lines so that does not show up anymore, thank you very much but i am still unable to set the speed in the vfd, it still starts at 300 rpm but it does not let me go faster, i have not found the line to configure that, thanks again
5 years 7 months ago #202508 by Aciera
I'm not familiar with that vfd component.
Are there any commands that work with your vfd using your current config?
5 years 7 months ago #202509 by santiagoe
the only way i found to go higher was to set the starting rpm to 10000 but that is the limit, i think that is not the right way to do it, i also tried changing the spindle max output in the ini file but that is not working
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 24000.0
5 years 7 months ago #202510 by santiagoe
hmm not sure how to figure that out. like commands in the hal files?
5 years 7 months ago - 5 years 7 months ago #202519 by newbynobi
This line is wrong:
net spindle-speed spindle.0.speed-out => vfd.speed-command
You need to give spindle.0.speed-out-rps to the vfd command.
You will need to scale the value, as your vfd will expect 0 to 10 V but spindle speed rps is I. Revolutions per second.
I am not on my PC, but maybe past tomorrow I can post my config
Last edit: 5 years 7 months ago by newbynobi.
Time to create page: 0.081 seconds
