Analog servo drive enable
5 years 7 months ago #202917 by PCW
Replied by PCW on topic Analog servo drive enable
Running away like that points to reversed feedback
Does it runaway with P = 0?
5 years 7 months ago #202923 by Hamel2020
Replied by Hamel2020 on topic Analog servo drive enable
I have one more question ...
How is the analog signaling from 7i77 at drives [0-5] (AUT0 , GND)
is it differential? or single ended ?
ie :
AUT0 => -10 to +10 V
GND => 0 V
or
AUT0 => +10 V
GND => -10 V
5 years 7 months ago #202926 by PCW
7I77 outputs are single ended.
5 years 7 months ago #203074 by Hamel2020
I noticed that , and I did the single ended wiring ... but still I was not able to do the PID tuning, I attached the hal and ini file.
I always get joint following error … just once I click jog … I got the servo spinning for a while then I got Joint following Error ..
5 years 7 months ago #203076 by PCW
Try setting FF1 to 0
Then it should just drift when enabled and ignore any jog
( FF1 = 1 is _way_ too high)
Then set P to a very small value (say .05)
and see if the motion tries to follow the command
when jogged or runs away
5 years 7 months ago #203122 by Hamel2020
Peter .... You rock
It works very well ....
Thank you very much :)
Time to create page: 0.412 seconds
