Radial toolpaths not working correct
5 years 7 months ago - 5 years 7 months ago #203780 by Tetsuoi
Hi
Im playing with toolpaths. Fusion 360 simulation shows correct, tool is getting to the center.
Also in Axis I can see lines in the center. But the result is this.
Any ideas where is the problem?
Last edit: 5 years 7 months ago by Tetsuoi.
5 years 7 months ago #203851 by andypugh
Are the overall dimensions correct?
5 years 7 months ago - 5 years 7 months ago #203862 by Michael
What are the modal g codes for the program? You can see them at the bottom of mdi box in axis. Or the first few lines in the code itself. Is there a G64?
If so type in G61 and run the program again. This should make it follow the exact path programmed. It looks like linuxcnc is running smoothing and the way some of those lead out/in moves ate being trimmed to keep speed.
Last edit: 5 years 7 months ago by Michael.
The following user(s) said Thank You: Tetsuoi
5 years 7 months ago #203961 by andypugh
Michael wrote: If so type in G61 and run the program again. This should make it follow the exact path programmed. It looks like linuxcnc is running smoothing and the way some of those lead out/in moves ate being trimmed to keep speed.
I think you have it.
linuxcnc.org/docs/2.8/html/user/user-con...#_trajectory_control
5 years 6 months ago #204759 by Tetsuoi
Michael there was G64.
Got it now how I wanted, thanks
Time to create page: 0.055 seconds
