Renishaw TP-20 Probe Connection
5 years 6 months ago #205183 by andypugh
I know just enough electronics to be dangerous, so I would rather not advise.
I don't know if you can just connect a PNP transistor to the +V rail and still have it driven by the op-amp output as shown.
This might help:
electronicsclub.info/transistorcircuits.htm
Based on that I think it would probably work to just move the transistor and swap the type. Breadboard it first?
5 years 6 months ago #205222 by dm17ry
a while ago i checked the renishaw PI4 probe interface unit - it supplies the probe with 12V limited to 0.5mA. so i think some circuit with a comparator before the optoisolated machine input would be a good idea...
The following user(s) said Thank You: eduard
5 years 6 months ago #205235 by jackdavies
Thanks to both for the info there, thats interesting that it supplies 12v.
I think I have found a way to do this, which actually was quite easy, I still need to actually test this circuit however!
Using the circuit shown here - electronics.stackexchange.com/questions/...g-5v-microcontroller
I have attached my revised circuit that should trigger the 24v input with the same transistor.
5 years 6 months ago #205289 by andypugh
Yes, that should work, but why not run the whole circuit off of 24V? It just needs a higher-voltage op-amp and making R4 proportionally bigger.
Time to create page: 0.116 seconds
