Home Limit Switch
5 years 6 months ago - 5 years 6 months ago #207161 by Michael
Replied by Michael on topic Home Limit Switch
You can have your values all he negative or all positive. Or some where in between. You could have the center of the table be 0,0
To clean it up for you if you want the home position to be in the right rear then all your values will be negative. The axis movement is all the direction the spindle travels relative to the table. Positive in x is right. Positive in Y is away or to the rear. Does the dro count the correct direction as I just stated?
What movent profile do you have? X axis spindle moves or table? Same question for Y and Z
Last edit: 5 years 6 months ago by Michael.
5 years 6 months ago #207164 by Jeff_in_Wa
Replied by Jeff_in_Wa on topic Home Limit Switch
So, I am going to follow your lead. I will move all the numbers to put the table into the negative. So far I haven't crashed the machine.
The gantry moves, not the table. Spindle min/max on X
Two motors on the Y's
5 years 6 months ago #207165 by Jeff_in_Wa
Ok! I changed my min / max limits as you suggested. The machine seems to be homing perfectly, but I am now getting these errors:
"Exceeded negative soft limit (1117.00) on Joint 0
joint must be unhomed, jogged into limits, rehomed"
Same for joint 1 & 2 (Y's)
Here is the Joint 0 Code:
[AXIS_X]
MAX_VELOCITY = 150.0
MAX_ACCELERATION = 200
MIN_LIMIT = 1117
MAX_LIMIT = -0.001
[JOINT_0]
TYPE = LINEAR
HOME = -12.0
MIN_LIMIT = 1117
MAX_LIMIT = -0.001
MAX_VELOCITY = 200
STEPGEN_MAXACCEL = 220
SCALE = 80.0
FERROR = 1
MIN_FERROR = 0.25
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = 30
HOME_LATCH_VEL = -5
HOME_SEQUENCE = 1
5 years 6 months ago #207167 by Jeff_in_Wa
I've got the machine homing without errors, but can't jog away from the switches. I think I must have to zero out the coordinates. Not sure...
5 years 6 months ago #207169 by Jeff_in_Wa
After homing my machine, this is what the DRO is showing. Shouldn't it be at 0,0,0 or at my home offset of 12mm's?
X: -576-61 DTG: 0.000
Y: -324.12 DTG: 0.000
Z: 74.95 DTG: 0.000
G54: X: 21.157 G92: X: 555.10
G54 Y: 21.092 G92: Y: 303.139
G54 Z: -7.532 G92: Z: -79.444
G54 R: 0.000
TLO X: 0.000
TLO Y: 0.000
TLO Z: 0.000
Vel: 0.000
The machine homes, but I can't move the spindle away from the switches
5 years 6 months ago - 5 years 6 months ago #207176 by Michael
Your still a bit backwards. If on the x axis the spindle moves left to right and the homing switch is on the right then you would need the right hand value (max) to be positive or larger than the left hand value (min).
[AXIS_X]
MIN_LIMIT = -1116
MAX_LIMIT = -1
[JOINT_0]
TYPE = LINEAR
HOME = -12.0
MIN_LIMIT = -1116
MAX_LIMIT = -1
MAX_VELOCITY = 200
SCALE = 80.0
FERROR = 1
MIN_FERROR = 0.25
HOME_LATCH_VEL = -5
HOME_SEQUENCE = 1
Make the changes in red. This is assuming the axis moves the correct direction. Also use the mdi and enter G53 or switch the dro to display actual position. Your last DRO reading was in relative, most likely the G54. When in G53 the units displayed will be the same as what is listed in your ini file as far as the machines position.
The above setup while homing should move the x axis in a positive direction (right) to reach the home switch at 0.
Then move off the switch to -12
Then you should be able to jog in the range of -1116 to -1 and never get closer than 1mm to your switch, which would now be a limit switch. Just make sure you are looking at this in G53 or actual position.
The following user(s) said Thank You: Jeff_in_Wa
Time to create page: 0.319 seconds
