tool prepare
5 years 6 months ago #207187 by snujcnc
Replied by snujcnc on topic tool prepare
You are right ...I also feel that tool prepare is not suitable for turret
But when I use tool change
I need enter every time TX M6
For machining Center is ok
But for lathe general theory is to use TX only to call tool on lathe turret tool
Is there any way we can use M6 in Plc only no need to call M6 in program
And use tool change function
Please guide
5 years 6 months ago #207188 by snujcnc
I already link Hal file to ini file
And all signal I can use in Plc
Like
Tool prepare
Tool prepared
Tool change
Tool changed
5 years 6 months ago #207189 by snujcnc
I connect tool prepare directly to prepared
And with Change he signal
I unclamp turret
After confirmation unclamp
I rotate tool disk
Then at match number position
I stop Fisk and clamp turret
But some time turret miss behave
I want to know
Tool prepare signal always pop up
If I use auto program and call two tool in one ore gram
When first tool changed and program running for cutting task
Same time that second tool which prepare signal again pop up
And this is point I am confuse
I only want
When I call tool only that time tool prepare signal show me
In auto program with two tool used
5 years 6 months ago #207195 by cmorley
Replied by cmorley on topic tool prepare
You need to remap the toolchanfe codes.
Look at the AXIS simulation config...fanucy...it uses remap to change tool with only t code.
5 years 6 months ago #207500 by andypugh
Replied by andypugh on topic tool prepare
When mah was active he was of the pinion that anything that could be done my remap should be done that way, rather than by core code changes.
I am coming round to the idea that this behaviour should be a switch in [EMCIO]
5 years 6 months ago #207553 by cmorley
Remap could be made much more friendly I think.
adding more standard remaps could help.(I added a couple)
Time to create page: 0.207 seconds
