First steps for re-doing electrical
5 years 5 months ago #207729 by rfrey
Hi. Very rookie questions here! I have an early Novakon machine. When I bought it several years ago it ran on Mach3 but the owner had re-done some of the electronics to make them more compact. With the help of a friend I did a bodge job on it to convert it to LinuxCNC using a 5i25 and 7i76. It worked for several years but the built-in Estops don't work, it has no end stops, there are several wires I've traced that don't seem to do anything, and I don't really understand the electronics which bugs me.There are no wiring diagrams or schematics.
The motherboard gave out, and I have no projects in the works so I thought I'd I'd take the opportunity to beat back some of the entropy and also learn how to do this sort of thing correctly. I've got ambitions to add a pendant and maybe a spindle encoder, and I'd like to do that in a non-random-walk kinda way. My questions:
  1. My cursory web search suggests that most industrial machines use ladder diagrams, but the examples I saw were all from the 80s or earlier. Is that still good practice in 2021? Should I skip directly to a schematic or a wiring diagram?
  2. How do people like to document the HAL design? Is the code good enough, or would a "pro" do some advance design on paper first, and if so, what techniques are used? Ladder diagrams again?
  3. Is there a tutorial or introductory article on basic design for cnc electronics circuits, as basic as putting in an e-stop loop, where to put fuses, etc? I can copy existing designs but a HOWTO would be awesome if it exists.
  4. Is there common software that people like to use for the designs, or is a bic pen the best technology?
  5. Is this a terrible idea, and should I leave well enough alone?
  • BeagleBrainz
  • New Member
  • New Member
5 years 5 months ago #207739 by BeagleBrainz
Replied by BeagleBrainz on topic First steps for re-doing electrical
In the middle to almost finished redoing the electrical myself.
Did everything in my head, but did check each section as I went along, rather than doing everything then hoping it would work.
Did cheat somewhat by designing a pcb to make wiring if the self holding relays easier.
Get a lot of bootlace ferrules and a decent crimper to make life easier.
If you want diagrams use whatever CAD package you feel comfortable with I guess.
Whichever way you do it, be neat & logical. It’s far easier to fault find when it’s all neat rather than a rat’s nest.
I guess designing everything in my head isn’t the most logical way to do it.
5 years 5 months ago - 5 years 5 months ago #207746 by nonspecialist
I`m also sorting a controller. After a fitful start I created a bill of materials at the same I time placed IEC symbols in a drawing. Listing every part number.For a rookie a bic pen is probably better than trying to do everything in ones head. I found a pdf called Example Standard Mill Electrical Drawing CNC CONTROL SYSTEM ELECTRICAL CIRCUIT DIAGRAM while searching for examples to follow. I found I could edit it in Linux`s Libra Office without having to start from scratch in Mechanical Desktop which not everyone has. I'm seeing more plans submitted in pdf format in professional settings so it might be an easy way to get started. The advantage of using graphics apps over pen and ink is being able to save and change as often as wanted and also being able to share it with anyone who might be willing to give advice. You can also include details about every part. Details found by doing search's for every part number. These part number lead to datasheets by way of understanding the electronics. I organize data sheets along the form of circuit paths / bill of materials. I don't wish to promote any particular supplier if that is considered spamming here. But understanding the electronics is greatly helped when the company behind your part numbers has excellent documentation. Even if you don't buy from them industrial automation equipment makers allow users to download guides. Some as basic as where to put fuses to overviews of control box layout including recommended parts.
Last edit: 5 years 5 months ago by nonspecialist. Reason: Assuming company names not allowed ?
5 years 5 months ago #207749 by tommylight
@nonspecialist
That is considered SPAM around here and it is frowned upon, vigorously !
5 years 5 months ago #207888 by rfrey
It seems like the e-stop circuit is the hardest, and if I get that I'll have it licked. That's probably naive but I'm going with it.
estop-ext will be tied into the estop-latch component that I've read about here, so that either the software or the hardware can trigger the estop, but if it's triggered it will have to be cleared on both hardware and software.
Does this look reasonable? Am I missing something?
5 years 5 months ago #207890 by PCW
The AC VFD contactor is in series with the step motor power relay (should be in parallel)
Also its likely that the step motor drives will not like switching their DC power.
its better to switch the AC side of the step motor power supply.
Time to create page: 0.062 seconds
