First steps for re-doing electrical
5 years 5 months ago #207901 by rfrey
Ah, thanks a million! Comme ca?
5 years 5 months ago #207904 by PCW
That looks good.
5 years 5 months ago #207917 by rfrey
Thanks, I appreciate the guidance.
My mill has a base cabinet that has a big opening in the back with a door. I was planning on putting the electronics on a panel and then attaching that to the side of the cavity with drawer slides.
Is there any reason the panel has to be metal? Can I use plywood or do I need a big grounded surface?
  • BeagleBrainz
  • New Member
  • New Member
5 years 5 months ago - 5 years 5 months ago #207925 by BeagleBrainz
Replied by BeagleBrainz on topic First steps for re-doing electrical
I’d use a metal plate and run a bonding strap to the main earth.
There could be a chance if you rely on the draw slides alone you may end up with different earth potentials.
A timber back plate would provide functionally no earth which would not be a good idea if a mains live wire became dislodged.
That’s just my two cents.
Last edit: 5 years 5 months ago by BeagleBrainz. Reason: Off topic
Time to create page: 0.150 seconds
