How to test real-time performance of linuxCNC RTAI?
5 years 5 months ago #209873 by hitmanlinuxcnc
How to do the kernel latency, switch, and preempt tests?
Or other real-time performance tests?
I have installed the linuxCNC with RTAI.
I also ran the ''Latency Test" given by LinuxCNC.
Thank you.
5 years 5 months ago #209874 by hitmanlinuxcnc
I found the following:
github.com/relacs/makertai
But It seems that this demo is for Linux with RTAI ?
I am a beginner.
  • BeagleBrainz
  • New Member
  • New Member
5 years 5 months ago - 5 years 5 months ago #209883 by BeagleBrainz
Replied by BeagleBrainz on topic How to test real-time performance of linuxCNC RTAI?
For general Linuxcnc use, the boys have put a of of work into, if your machine passes the latency test you are good to go. From memory there should be some scripts in /usr/src/rtai/"your kernel version" that you can run.
If you want to learn more about RTAI this link should be of help: www.rtai.org/
The github link you gave looks like it is for building a testing a "generic" RTAI kernel.
Last edit: 5 years 5 months ago by BeagleBrainz.
5 years 5 months ago #209892 by tommylight
Tools included with LinuxCNC:
latency-histogram
latency-test
latency-plot
The following user(s) said Thank You: hitmanlinuxcnc
5 years 5 months ago #209960 by Arthur_L
Excuse me, are you using the source code to compile and install RTAI which version of RTAI do you use? Can you give me a copy of your compilation instructions. Thank you
5 years 5 months ago #209973 by hitmanlinuxcnc
Our team failed to install RTAI in debian linux.
Then, we installed linuxCNC-debian with the RTAI in our controller.
Time to create page: 0.339 seconds
