Motion digital output value on stop
5 years 3 months ago #214431 by rajewski
I'm using a motion.digital-out signal to control my dust collector from gcode. I got everything working well and got it all tied into my post.
I've run into one problem though. If I disable the machine or stop the program in the middle, the "M65 P3" is never run so the dust collector stays on.
Is there a way to ensure this runs or set a default value if a program is stopped or if the machine is disabled?
I know I could use an and2 component in my HAL to gate the signal if the machine is enabled but this wouldn't solve the stopped program problem. It would also start the dust collector back up if I re-enabled the machine.
5 years 3 months ago #214436 by PCW
You could gate it with a signal indicating motion
( maybe a near component looking at motion.current-vel )
5 years 3 months ago #214441 by rajewski
Gating it doesn't solve the problem of it still being "on". For example, if I was running a program that used the dust collector but stopped it then started another program that didn't use the dust collector, the dust collector would turn on when the second program started.
Is there no way to "hook" into when a program is stopped or the machine is disabled to run a script?
5 years 3 months ago - 5 years 3 months ago #214445 by PCW
You could change the default startup gcode to turn off the digital output
Or add this to you other programs
There is probably a way to launch a script maybe by monitoring
halui.program-is-running
Last edit: 5 years 3 months ago by PCW.
5 years 3 months ago #214447 by tommylight
Not sure if there is a pin
program is running
as AND-ing that with the digital output would achieve what you need, namely stopping the output if the program is stopped but would remain on if the program is paused.
Pretty sure RodW used something similar for warning lights.
5 years 3 months ago - 5 years 3 months ago #214451 by rajewski
Is it possible to trigger a script or gcode when a HAL pin changes? I haven't seen anything in my search of the docs but I could be missing something.
If I gated the output with the machine enabled signal and was able to change the state of the motion.digital-out pin on the falling edge of halui.program.is-running I think it would do more or less everything I want.
Edit: My machine doesn't use flood coolant. Do you know if this automatically gets turned off when the program is stopped? I could repurpose this signal.
Edit again: This seems to have worked exactly as I wanted.
Last edit: 5 years 3 months ago by rajewski.
Time to create page: 0.329 seconds
