How to configure a 7c81 with a 7i73
5 years 3 months ago #214899 by JAMSys
Can someone please tell me how to configure a 7c81 board with a 7i73 ?
The is no bit file for the 7i73.
Thanks in advance.
5 years 3 months ago #214901 by tommylight
7i73 is a SSERIAL device so does not need a bit file for it to work.
Wire it properly, connect it, there should also be something to change in hal regarding SSerial address, and that should just work.
5 years 3 months ago #214903 by JAMSys
OK, Thank you.
It would be very helpful to have an example HAL file for the 7c73 part.
5 years 3 months ago #214925 by PCW
Hardware wise, The 7I73 should "just work" if connected
to the 7C81's J1 or J2 connectors.
You might make post "Need 7I73 Jogging example" or
something else specific to your needs on the forum,
as this is not really a 7C81 question.
Time to create page: 0.326 seconds
