- Thank you received: 37
SoE Ethercat
- TheRoslyak
- Topic Author
5 years 3 months ago #215959
by TheRoslyak
SoE Ethercat was created by TheRoslyak
Hi everyone
I corresponded with enginer of Hungary company NCT.
They used SoE protocol to sent Ethercat package. (IDN S-0-0134 is controlworld and etc.)
It is new for me. Do is suporting linuxcnc this protocole?
- rollfree
- Thank you received: 11
5 years 3 months ago #215988
by rollfree
Replied by rollfree on topic SoE Ethercat
Yes. With EtherCAT master package from IgH.
- TheRoslyak
- Topic Author
5 years 3 months ago #216037
by TheRoslyak
Replied by TheRoslyak on topic SoE Ethercat
Thanks for the detailed answer.
I wanted to get configuration examples, but already found it myself
The following user(s) said Thank You: HalaszAttila
- rollfree
5 years 3 months ago - 5 years 3 months ago #216087
by rollfree
The question was if LinuxCNC supports EtherCAT SoE.
The answer was 'yes', and what else would need to be installed on LinuxCNC.
So why sarcasm?
So why sarcasm?
Last edit: 5 years 3 months ago by rollfree.
- kubabuda
5 years 3 months ago #216216
by kubabuda
Replied by kubabuda on topic SoE Ethercat
SoE as SERCOS over EtherCAT? Where can I find example Linux CNC setup for those? So far I have seen only CoE with CiA402 profile for motion control.
- rollfree
5 years 3 months ago #216220
by rollfree
docs.google.com/document/d/1GiB065ZIAaoM...n-19xGQl2X9DM9-THNM/
For example:SoE as SERCOS over EtherCAT? Where can I find example Linux CNC setup for those? So far I have seen only CoE with CiA402 profile for motion control.
The following user(s) said Thank You: kubabuda
- HalaszAttila
- Thank you received: 5
2 years 2 months ago #308115
by HalaszAttila
Replied by HalaszAttila on topic SoE Ethercat
Hello,
Did you manage to get the NCT plc and Linuxcnc working together?
- TheRoslyak
- Topic Author
2 years 2 months ago #308122
by TheRoslyak
No, in the end, I didn't take their equipment because there weren't any significant advantages. I just talked to them at the exhibition. But SoE can be easily adapted to LinuxCNC.
Time to create page: 0.133 seconds
