Best way to do external controls for LinuxCNC
5 years 1 month ago - 5 years 1 month ago #220136 by FDP
For some reason I assumed that since Python compiles to bytecode it would be able to run in realtime.
Do you think a reasonable workaround would be to write a C/C++ library and then make a Python wrapper using CTypes?
Last edit: 5 years 1 month ago by FDP.
5 years 1 month ago #220220 by Roiki
Just because it compiles into bytecode doesn't make it realtime capable if there's nothing to run that bytecode with. The realtime modules are just linux kernel modules. Linux kernel modules are written in C(and rust in the future).
The linuxcnc python api is a wrapper to the c++ api. I don't know what library you're wanting to make but most of the functionality is already there.
5 years 3 weeks ago #222315 by andypugh
You might want to look at:
linuxcnc.org/docs/2.8/html/man/man1/halrmt.1.html
linuxcnc.org/docs/2.8/html/man/man1/linuxcncrsh.1.html
linuxcnc.org/docs/2.8/html/man/man1/linuxcncsvr.1.html
The last one exists, but I have no idea how to use it. If you figure it out then perhaps you can add to that manpage?
5 years 3 weeks ago #222365 by arvidb
Thanks @Roiki. Do you know why Python 3 can't run as realtime code using PREEMPT_RT?
You could run the Python interpreter as a realtime process, but the interpreter's garbage collector will kick in at random times which means your program still won't be time deterministic. You simply can't control the latency between "instructions" in Python.
5 months 2 weeks ago #346336 by grijalvap
Any bpdy in the forum heve used this gRPC
github.com/dougcalobrisi/linuxcnc-grpc
not sure if it is real time but I think is an interesting aproach sinse GRPC is lenguaje agnostic
prety well supported and i think the c++ or RUST version can run deterministic
Time to create page: 0.409 seconds
