- Thank you received: 25
axis without limits
- RobotMatic
- Topic Author
5 years 4 weeks ago #222237
by RobotMatic
axis without limits was created by RobotMatic
is it possible to move an axis without limit of length?
I need to rotate a roller incrementally without having a maximum and minimum limit , it's for a hot stampin machine.
performs a single axis setup, and an .ngc file with an incremental G code, but stops when it reaches the limit of the axis
How could I tell Linuxcnc that the axis does not have machine limits, so that the roller rotates infinitely ?
Thank You
Thank You
5 years 4 weeks ago #222258
Replied by Aciera on topic axis without limits
If the limits are undefined in the [JOINT_] and [_AXIS] sections of the ini file then the values default to +-1E99.
- RobotMatic
- Topic Author
5 years 4 weeks ago #222277
by RobotMatic
Replied by RobotMatic on topic axis without limits
I am using 2.7.15.
It is not possible to define an axis without limitis, an out of limit error occurs.
In order to carry out this project of making a roller rotate continuously, I need to have an axis without limits, since although there is a measure to be executed, which is the length of the paper to be moved, the sum of many displacements exceeds any minimum or maximum limit. required by Linuxcnc
5 years 4 weeks ago - 5 years 4 weeks ago #222278
Not sure about this as I only run 2.8 and later but it is stated in the documentation:
linuxcnc.org/docs/2.7/html/config/ini-co...s__lt_num_gt_section
- MIN_LIMIT = -1000 - The minimum limit for axis motion, in machine units. When this limit is reached, the controller aborts axis motion. The axis must be homed before MIN_LIMIT is in force. For a rotary axis with unlimited rotation having no MIN_LIMIT for that axis in the [AXIS_n] section then the value -1e99 is used.
- MAX_LIMIT = 1000 - The maximum limit for axis motion, in machine units. When this limit is reached, the controller aborts axis motion. The axis must be homed before MAX_LIMIT is in force. For a rotary axis with unlimited rotation having no MAX_LIMIT for that axis in the [AXIS_n] section then the value 1e99 is used.
Last edit: 5 years 4 weeks ago by Aciera.
- RobotMatic
- Topic Author
5 years 3 weeks ago #222295
by RobotMatic
Yes, I have read that, that's why I asked if it was possible in some way to program a free axis, or define it free without limits.
thank you
thank you
5 years 3 weeks ago #222304
by BigJohnT
Replied by BigJohnT on topic axis without limits
Don't make it an axis, rather just use hal to drive the motor. Take a look at my stepper winder example.
gnipsel.com/linuxcnc/examples.html
JT
JT
Time to create page: 0.411 seconds
