axis without limits
5 years 3 weeks ago #222305 by RobotMatic
Replied by RobotMatic on topic axis without limits
I did not know that it could be done this way!
I will look at it!!! thanks again!!! JT
5 years 3 weeks ago #222336 by Aciera
Replied by Aciera on topic axis without limits
Mind you 1E99 is a lot of paper even if you measure it in microns.
5 years 3 weeks ago #222356 by andypugh
Replied by andypugh on topic axis without limits
It's 100000000000000000 x the number of atoms in the universe...
5 years 3 weeks ago - 5 years 3 weeks ago #222364 by arvidb
Replied by arvidb on topic axis without limits
Maybe that 1e99 default is "somewhat" too lax. Double precision floating point only guarantees 15 significant digits, so if we want to ensure correct representation of, say, 0.001 machine units, we should probably limit the limits to +/-1e12 or so.
Edit: but even 1e12 mm = a billion meters is some 25 times around the Earth, so... that would be a BIG lathe, or quite a lot of paper! :)
Edit2: ... unless you're making toilet paper for the entire world. Then you'd run into that 1e12 mm limit after [url=
www.theworldcounts.com/challenges/consum...let-paper/story]just a little over 4 hours[/url]! *lol* Maybe I should drop this subject now?
Last edit: 5 years 3 weeks ago by arvidb.
Time to create page: 0.081 seconds
