OPC UA
3 years 2 days ago - 3 years 2 days ago #284128 by TheRoslyak
Replied by TheRoslyak on topic OPC UA
Well, yes, there is such a point. It's strange that I need to inform Linuxcnc users. Opc ua is an even more widespread term than linuxcnc :). For an overview, you can check out this guy:
www.youtube.com/playlist?list=PLIrJJXPVF...sA9tta8yULOB8nPUO_G7
I haven't even mentioned that there's also Opc UA TSN (FX). I uploaded a new version and fixed the bug with iocontrol.0.user-enable-out.
UPD.Perfect!!! Now the variable write function is working there too.
Last edit: 3 years 2 days ago by TheRoslyak.
The following user(s) said Thank You: bkt
3 years 1 day ago #284181 by TheRoslyak
Overall, work is completed. The server works perfectly. In Prosys, you can build graphs with a frequency of 100ms. UaExpert at a frequency of 50ms. If you create the client yourself, then I think it will work at the speeds of the HAL environment.
You can change variables that aren't available in halmeter.
And those variables that can't be changed - they log that everything is fine, but the variable doesn't actually change. Perhaps in the future, it will be possible to create a tree structure like in halshow. Or add some logs. Anyway, check it out. It might be useful for someone.
The following user(s) said Thank You: Mecanix
3 years 9 hours ago - 3 years 9 hours ago #284263 by Mecanix
Replied by Mecanix on topic OPC UA
Worth a look. We used to run offsite mechatronic hardware hosted by a PLC and an OPC server, that was in NX MCD (Siemens). Also widely used for virtualization and commissioning. That was like a decade+ ago however very much being developed and still in use today.
Reason I'm saying this is, I see endless potential.
Last edit: 3 years 9 hours ago by Mecanix.
3 years 6 hours ago #284268 by poesel
Replied by poesel on topic OPC UA
I use OPC UA on the job more or less daily. So I know what it is and what it does.
But I don't understand what the point is to have an OPC server with linuxcnc?
What do you do with it? Monitor? Control?
Please don't get me wrong. I find this interesting, but I just don't get the purpose.
3 years 6 hours ago #284272 by Mecanix
The exposure this project bring to lcnc is positive. Purposes are unlimited; resiliency, scalability, data integrity and/or security, etc etc. Perhaps not well adapted for e.g. a home R&D (like mine) however more so in an industrial/scalable setting.
3 years 2 hours ago #284290 by TheRoslyak
The thing is, I'm developing my own application similar to Codesys and Twincat using the HAL environment. Specifically, this utility is a universal solution that is also suitable for Linuxcnc. With its help, you can monitor the status of a machine (robot) while sitting in the restroom or while moving in the subway.:-) But it also allows you to change the value of variables on the fly, which halmeter does not allow.
