Feedback loop following error
4 years 10 months ago #228322 by chris@cnc
This line not change. This your command Position data. Check this data in halshow. You must search why your velocity data or command data not stop. I can not See what is wrong,
4 years 10 months ago #228323 by bobi4ko23
Okay after i see the results i will send you tomorrow. Thank you very much for your help.
4 years 10 months ago #228468 by bobi4ko23
Sorry for the late reply, had a lot of stuff to do, and finally got around to testing today. Turns out it was a wiring issue in that the encoder pulses were switched and the encoder was counting backwards (yeah big brain over here). Now on to the PID settings. Can someone tell me how to reduce the starting peak to a more reasonable level? And also does backlash compensation even do anything if I have encoder feedback?
Thank you everyone for helping me and my rookie butt to figure everything out.
Time to create page: 0.182 seconds
