Linuxcnc Image for Raspberry Pi 3
29 Nov 2021 11:24 #227928 by tsewell
Linuxcnc Image for Raspberry Pi 3 was created by tsewell
Does anyone have an image they could share for Linuxcnc for a Pi 3? I know this Pi is not as preferred as the 4, but it should do fine with the 7C80 I have it mounted on (using SPI instead of ethernet). Most of the links I have found in this forum using the search no longer work.
Thanks,
Travis
  • Moderator
  • Moderator
29 Nov 2021 13:32 #227939 by tommylight
Replied by tommylight on topic Linuxcnc Image for Raspberry Pi 3
Did you try the one found here:
linuxcnc.org/downloads/
29 Nov 2021 14:03 #227941 by tsewell
Replied by tsewell on topic Linuxcnc Image for Raspberry Pi 3
My understanding is that that image is for the Pi4. I did try it however, and it did not boot on the Pi3- I got a rainbow screen with no progress from there.
Thanks though!
  • Moderator
  • Moderator
29 Nov 2021 16:28 #227955 by tommylight
Find an official image that works on PI3, then try to install one of these kernels:
github.com/kdoren/linux/releases
If that goes OK, follow the instructions on buildbot.linuxcnc.org to add the repositories and install LinuxCNC.
I could not find any ready made image.
The following user(s) said Thank You: tuzki, NWE
07 Dec 2021 03:41 #228520 by rodw
Replied by rodw on topic Linuxcnc Image for Raspberry Pi 3
I think I'd try getting Debian 11 up and running. Then get the preempt_rt  kernel from the debian repos.
You will need to compile Linuxcnc from scratch but that is not overly hard (not sure on the Pi though)
The following user(s) said Thank You: NWE
07 Dec 2021 04:34 #228524 by slc
Replied by slc on topic Linuxcnc Image for Raspberry Pi 3
This just came up on Youtube yesterday.
It's not a link to a compiled image but worth a look.
I have just compiled linuxcnc on an Xubuntu system to use as a simulator for checking gcode files, it is not difficult just a bit of a faff managing dependencies.
10 Dec 2021 14:00 #228800 by tsewell
After some research and fiddling, I was able to get the 2.8.0 image to boot on my PI 3B!
In config-rt.txt file on the SD card (once the image was flashed to the SD using the Raspberry PI tool) I changed this:
[pi4]
kernel=vmlinuz-4.19.71-rt24-v7l+
force_turbo=1
to this:
[pi3b]
force_turbo=1
I still got the CPU 0 error on initial power up, but it seems to boot and work just fine.
10 Dec 2021 14:50 #228816 by tsewell
On version 2.8.1, I did the above, plus renamed the kernel from kernel7l to kernel, and it booted just fine as well!
03 Dec 2025 01:29 #339675 by masawee
Replied by masawee on topic Linuxcnc Image for Raspberry Pi 3
not understand what is compile and how need do ? or have ready to use image to rpi3.
i looking make rpi3 linuxcnc small cnc my son.
or how kernel need use or how can change kernel or what need doing. too hard all linux system but have only what can use good whit linuxcnc and rpi3 board. not want buy old computer and paraller port use this.
03 Dec 2025 01:35 #339676 by masawee
this link has only pi 4 images, not any oi 3. what need doing can use pi 3 and linuxcnc, what is patch and how need doing, or what need doing, not understand , ready to install pi 3 image only need how need patch or what this mean and how change kernel if need no understand anything linux and code, secret engineer language all.
Time to create page: 1.733 seconds
