upgade z axis
4 years 8 months ago #234318 by Nate
upgade z axis was created by Nate
so i upgraded my z axis today and i am needing help changing my in per revolution in a working plasmac configuration
4 years 8 months ago #234322 by tommylight
4 years 8 months ago #234934 by Nate
Replied by Nate on topic upgade z axis
Good morning is there a way i can do this or do i need to create a new configuration file
4 years 8 months ago #234955 by tommylight
Replied by tommylight on topic upgade z axis
You can edit the INI file.
You should really provide us with more info when asking.
If it is a stepper system, then each axis/joint section in the ini file will have step_scale, set that to how many steps per inch the machine moves.
Time to create page: 0.239 seconds
