Using Python for axis motion control
4 years 8 months ago - 4 years 8 months ago #235014 by mh300
Hello LinuxCNC Community,
I recently bought an old Industrial Mill (Maho MH 300 P), it's already sort of CNC, but with just one Motor that drives all three axes (one axis at the time). Since the old feed motor is worth more on the replacement market than a brand new Siemens Servo Drive + Motor, I already retrofitted the machine with a Siemens Servo controller and a small PLC.
Long term, I plan to do a full CNC conversion, with one servo motor per axis - I would like to use two additional Siemens servo drives (Siemens SINAMICS V90). As the CNC Control, I would like to use Linux CNC - but here I need to communicate with the drives via some specific protocols that are not supported by LinuxCNC as far as I know (Profinet/Profidrive).
I would like to use Python to interface with the drives. Are there any good examples for doing axis motion control using a python module?
Alternatively, if there is no way to do the axis motion control from python, are there any good C examples?
Last edit: 4 years 8 months ago by mh300.
4 years 8 months ago #235096 by cmorley
If you want to use python for coordinated movement, that is not going to work.
C would work, it can be made realtime.
What physical interface to the computer will you use?
Do you know the protocol and can program C?
4 years 8 months ago #235133 by Roiki
Hal_streamer has a python api that you can use to stream component has a python api that you can use to Stream data from a queue to HAL. You can't inject it into the motion planner so the motion wouldn't be coordinated though.
4 years 8 months ago #235142 by mh300
Thank you for your replies.
The Real-Time aspect is of course true, I wonder how bad it would be though, the 500mm/min moves aren't the fastest and I think the µm precision is a lost cause already. image missing /media/kunena/emoticons/laughing.png But to answer your questions:
The normal Ethernet Interface of the computer is used. Profinet works with standard Ethernet frames, TCP/IP is also used but only for the configuration of the devices. (Can be done with an external tool)
I have access to the Spec, but writing a full Profinet Controller (=Master) would be a massive undertaking. For a first test, I plan to use OPC UA, which has a pretty sophisticated C library available ( Github ). CodeSYS would take care of translating between OPC UA <-> Profinet and can be made to run in Realtime.
As for programming C: My skills are a bit rusty, but If the Linux CNC interface isn’t too complicated and on the other side I just need to work with the existing OPC UA library, I think I will manage to get it running.
In general, how do the Interfaces for the Mesa Cards or EtherCat (with Servo drives) work in Linux CNC, are they deeply embedded in the LinuxCNC build or are they more like PlugIns?
Also, does LinuxCNC run the position control loop and the drive runs the velocity control loop? In this case, could LinuxCNC just pass me the velocity set point and I pass back the actual position of each axis?
Thank you for your help so far, it is greatly appreciated.
4 years 8 months ago #235313 by cmorley
You would need to build a HAL component to communicate through Ethernet to the drive.
For servos the usual set up is for linuxcnc to send velocity commands and read position feedback.
4 years 8 months ago #235318 by rodw
Ethercat is a standalone environment and there is a  HAL driver that lets Linuxcnc to connect to it
There is a CIA402 driver which may be of interest to you
github.com/dbraun1981/hal-cia402
CIA402 is a standard for servo drives.
Time to create page: 0.233 seconds
