USB Pendant Preventing Booting
4 years 8 months ago #235536 by devils4ever
Hi all,
This is my first post and I'm hoping someone here can help me. I'm running LinuxCNC on an ASUS Q1900B-ITX motherboard. It's been running fine. I just added a P2-S USB Pendant from VistaCNC. The pendant works great except I can't boot with it plugged into the USB port. If I plug it in after booting, all is well.
If it is plugged in while booting, I see the GRUB loader and then I get messages similar to this:
[ 8.12345678] CPU1: Not responding.
[16.12345678] CPU2: Not responding.
etc.
Can anyone help?
THANKS!
4 years 8 months ago #235543 by Aciera
Have you disabled USB as boot device in the BIOS?
4 years 8 months ago #235545 by devils4ever
Yes, I looked in the BIOS and the only bootable device listed is the SSD.
4 years 8 months ago #235881 by GeneRF
I have exactly the same MB and pendant. Always works fine, with no boot issues.
Make sure that Fast Boot is disabled and Wake from Lan is disabled. I have a hard drive rather than an SSD, but that should not matter.
It has been quite a while, but I believe everything else related to boot is still default.
4 years 8 months ago #235905 by devils4ever
I checked and both Fast Boot and Wake from Lan are disabled.
I bought a USB hub with switches for each port. I have to leave the pendant switched off until after boot, then turn it on before starting the LinuxCNC app.
Obviously, this is not ideal, but I'm running out of ideas!
Time to create page: 0.249 seconds
