Linuxcnc IDE
4 years 3 months ago #247298 by Reinhard
Replied by Reinhard on topic Linuxcnc IDE
Learn how to use grep and don't search for linuxcnc items in my project!
Go to source-tree of linuxcnc and issue some grep -R "whatever-u-search-4"
If you don't know the exact casing of your search pattern use grep -Ri "..."
lowercase-i stands for "ignorecase".
4 years 3 months ago #247354 by udoS
Replied by udoS on topic Linuxcnc IDE
@Reinhart ... thanks; that was easy;
Now in your FalconView git you say :sample directory contains two cmake files indispensable for successful build:
  • FalconView.cmake
  • FindlinuxCNC.cmake
There is a FindlinuxCNC.cmake ;
But there is NO FalconView.cmake ; ?
4 years 3 months ago - 4 years 3 months ago #247375 by udoS
@Reinhart ...
Now I'm getting these output:
VM: new model created for > "dtgW" <
language: QLocale::German
country: QLocale::Germany
syslocale: "de_DE"     current locale: "de_DE"
translation-messages: "Ch" FAILED to load
translation-messages: "cmake_inst" FAILED to load
translation-messages: "CMake" FAILED to load
translation-messages: "CMakeLists" FAILED to load
translation-messages: "Condition" FAILED to load
translation-messages: "EXT" FAILED to load
translation-messages: "Falco" FAILED to load
translation-messages: "FalconView_" FAILED to load
translation-messages: "Makefile" FAILED to load
translation-messages: "qtcsetti" FAILED to load
translation-messages: "" FAILED to load
GK::fileName4( "ini" ) =>  "/home/udos/linuxcnc/configs/sim.axis.gantry/gantry_mm.ini"
ToolTable::processFile( "/home/udos/linuxcnc/configs/sim.axis.gantry/sim.tbl" )
tool-image-dir:  QFileInfo(/home/udos/linuxcnc/configs/sim.axis.gantry/)
    found  3  active axis. Mask set to: 7
could not create database: Unbekannter Fehler -2
Press <RETURN> to close this window...
Last edit: 4 years 3 months ago by udoS.
4 years 3 months ago #247700 by BigGray
Replied by BigGray on topic Linuxcnc IDE
@tommylight
maybe imgui is for you. Mit licence, only need to write own event system.
4 years 3 months ago #247712 by tommylight
Replied by tommylight on topic Linuxcnc IDE
@tommylight
Looks promising, will have a longer look if i get a chance, thank you.
ASUS ROG Crosshair VIII Impact - AMD X570
Time to create page: 0.062 seconds
