- Thank you received: 139
To clarify - I have a solid state relay (NO) now and basically need a signal from LinuxCNC to my MESA output pin hm2_7i76e.0.0.output-07 (which should de-energise if there is a fault in LinuxCNC to switch my emergency circuit).
What would be this signal be called in LinuxCNC?
Also as a second question why doesn't LinuxCNC have a pin hm2_7i76e.0.0.output-07_not basically inverting a signal to the output pin (similar to the input pins).
Does this makes sense?
Thank you!
PS: I Incorporated in the hal file already the e-stop_latch which works well but I believe that is not what you meant.
That is an excellent explanation. And you are right - I am fairly new to this business 3 days in.
I am still not sure the exact signal i should send out to my physical e-stop circuit.
- What is the typical fault signal called within Linux CNC that would be good to trigger the physical e-stop loop?
I got the spindle almost set up - I managed to send out my analog voltage. I only need to solder up the spindle cables and now I am wondering if I should get some shielded cables (for UVW, 240V and the braking resistor).
- What did you guys do? Did you spend the dollars?
And as you go along there are some other questions that came up as well:
- How do I know what my encoder scale is. I looked in the manual and couldn't find anything and also on the name plate there is nothing. Is there some sort of standard encoder scale (i.e. 100)?
- Another question that came up - I saw that you could run the spindle directly with PWM using the MESA 7i76e board. The servo I have would support that. Is there any advantages or disadvantages? Besides the fact that the setup of analog seems to be more common and quite easy to setup.
I appreciate all the help and I am genuinely impressed by the excellent support. I hope I will be able to pay this back... Cheers
