Encoder for engine 60h86-3008b
  • jarcysgru
  • Topic Author
  • Premium Member
  • Premium Member
4 years 3 months ago #248279 by jarcysgru
Encoder for engine 60h86-3008b was created by jarcysgru
This motor has two axles with a diameter of 8 mm, my question is if I can add an encoder to this motor and what kind of controller, if so, please give me some tips.
www.ebmia.pl/silniki-krokowe/11135-silni...0-86-3008b-31nm.html
4 years 3 months ago #248282 by JPL
Replied by JPL on topic Encoder for engine 60h86-3008b
You can in fact add an encoder to any stepper motor, including this one.
First, you will need first to use an encoder with the correct bore (8mm) or machine the rear shaft to the correct size.
Then, you will also need to find a way to attach it to the back of the motor. Holes spacing are pretty much standardized but this motor appear to have no holes in the back. It is possible to drill and thread holes but difficult if you have not done that before. This is risky too since you should never drill too deep, which could damage the motor. I would then suggest to attach the encoder with double side tape or much better with epoxy.
Do a search for AMT102-V. It is a very good and not expensive encoder that I've used before.This is a 'kit' that also come with a 8mm sleeve that will make it fit the rear shaft directly.
For the 'controller', you can certainly use a combination of mesa card but I will let the experts elaborate about this since there's many possible choices. Have a look here: mesanet.com
  • Moderator
  • Moderator
4 years 3 months ago #248284 by tommylight
  • jarcysgru
  • Topic Author
  • Premium Member
  • Premium Member
4 years 3 months ago #248295 by jarcysgru
Replied by jarcysgru on topic Encoder for engine 60h86-3008b
What do you think, I won't have a problem with M2.5 threads
88,04 zł | NEMA 23 closedl pętli enkoder silnika krokowego 8mm płyta A B Singal 1000 linia dla NEMA 23 lub NEMA24 serwo krokowy
a.aliexpress.com/_vc8gpx
