7i92 + 7i76 + 7i84
14 Aug 2022 02:32 #249689 by rajsekhar
7i92 + 7i76 + 7i84 was created by rajsekhar
I am trying to configure a system with 7i92+7i76+7i84.
This is the first time I am using Mesa.
I have connected the ethernet cable
  1. computer-7i92
  2. 7i76RS-422 to 7i84
But I am little confused with the power connection. I want to supply separate power to each board. I have 5VDC, 12VDC, 24VDC available.
For 7i92:
As I will use separate power to 7i76, do I need to connect 5V power to 7i92??
I am using parallel port cable having 1:1 connection between DB25 ports (basically home soldered) and not shieled.
For 7i76 & 7i84:
I understand I need to connect 24VDC positive power to TB1 connector (pin 1,2,3,4 daisy chain) and GND to pin 8. Am I right??
should I daisy chain 6,7,8??
14 Aug 2022 02:43 #249691 by PCW
Replied by PCW on topic 7i92 + 7i76 + 7i84
If you are using separate 5V power for the 7I76 you need to supply 5V power to the 7I92 also
(make sure the 7I76 is jumpered to use 5V external power and the 7I92 is jumpered
to NOT supply 5V to the 7I76)
Yes 1,2,3,4 are 24V on the orange field power connector on both the 7I76 and 7I84
(only pin 8 or the orange connector need be connected)
14 Aug 2022 04:10 #249694 by rajsekhar
Replied by rajsekhar on topic 7i92 + 7i76 + 7i84
in 7i84, there is screw terminals on P5 and no terminals connected to P3.
Should I connect +5VDC to P5 top and GND to P5 bottom??
14 Aug 2022 04:34 #249695 by PCW
Do you mean 7I92?
Yes +5 on the top (this is shown in the 7I92 manual)
14 Aug 2022 07:26 #249700 by rajsekhar
I completed power connections.
But stuck in Network..I followed this thread
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
but on ping, its a failure.  "From 10.10.10.11 icmp_seq=1 Destination Host Unreachable" Refer attached file.
upon terminal command "mesaflash --device 7i92 --addr 10.10.10.10 -readhmid", resulted " No 7i92 board found". Refer attached file.
7i92 connected with 5VDC (4.99 VDC on measurement) power, LED status are as per attached photo and video.
All 7i92 jumpers are in default position.
What to do??
14 Aug 2022 07:37 - 14 Aug 2022 07:41 #249702 by Clive S
Replied by Clive S on topic 7i92 + 7i76 + 7i84
I think the default I.P. is in the 192.168.1.121 ish
So you have to set the jumper to the 10.10.10.10 range (its is shown in the manual)
W6 should be up
www.mesanet.com/pdf/parallel/7i92man.pdf
Last edit: 14 Aug 2022 07:41 by Clive S.
14 Aug 2022 08:08 #249704 by rajsekhar
Thank you. W6 made Up and problem solved. Its pinging, attached photo. Hope it is ok.
Another query:
7i92 is connected by DB25 cable to 7i76 and 7i76RS422 connected to 7i84.
What else networking to be setup for 7i76 & 7i84??
14 Aug 2022 10:11 #249707 by tommylight
Replied by tommylight on topic 7i92 + 7i76 + 7i84
No more networking, it is all good.
Use mesaflash to check what firmware is on the 7i92, you might need to flash the firmware for 7i92/7i76.
7i84 does not need any flashing or setup except maybe activating the SSerial port in the hal file.
14 Aug 2022 11:42 #249710 by rajsekhar
the terminal emulator data as follows:
raycnc1@debian:~$ mesaflash --device 7i92 --addr 10.10.10.10 --readhmid
Configuration Name: HOSTMOT2
  BoardName : MESA7I92
  FPGA Size: 9 KGates
  FPGA Pins: 144
  Number of IO Ports: 2
  Width of one I/O port: 17
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 2 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: QCount
  There are 1 of QCount in configuration
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: SSerial
  There are 1 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Instance Stride: 64 bytes
  Module: StepGen
  There are 5 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
Pin#                  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 1                      0   IOPort       StepGen          0        Dir/Table2      (Out)
14                      1   IOPort       StepGen          0        Step/Table1     (Out)
 2                      2   IOPort       StepGen          1        Dir/Table2      (Out)
15                      3   IOPort       StepGen          1        Step/Table1     (Out)
 3                      4   IOPort       StepGen          2        Dir/Table2      (Out)
16                      5   IOPort       StepGen          2        Step/Table1     (Out)
 4                      6   IOPort       StepGen          3        Dir/Table2      (Out)
17                      7   IOPort       StepGen          3        Step/Table1     (Out)
 5                      8   IOPort       StepGen          4        Dir/Table2      (Out)
 6                      9   IOPort       StepGen          4        Step/Table1     (Out)
 7                     10   IOPort       SSerial          0        TXData0         (Out)
 8                     11   IOPort       SSerial          0        RXData0         (In)
 9                     12   IOPort       SSerial          0        TXData1         (Out)
10                     13   IOPort       SSerial          0        RXData1         (In)
11                     14   IOPort       QCount           0        Quad-IDX        (In)
12                     15   IOPort       QCount           0        Quad-B          (In)
13                     16   IOPort       QCount           0        Quad-A          (In)
IO Connections for P1
 1                     17   IOPort       None
14                     18   IOPort       None
 2                     19   IOPort       None
15                     20   IOPort       None
 3                     21   IOPort       None
16                     22   IOPort       None
 4                     23   IOPort       None
17                     24   IOPort       None
 5                     25   IOPort       None
 6                     26   IOPort       None
 7                     27   IOPort       None
 8                     28   IOPort       None
 9                     29   IOPort       None
10                     30   IOPort       None
11                     31   IOPort       None
12                     32   IOPort       None
13                     33   IOPort       None
it is clear that P2 connector is configured. I am forwarding towards stepper connections.
14 Aug 2022 21:53 #249741 by tommylight
Moved to "driver boards".
Not sure but to me it looks like the firmware is OK for 7i76.
Use PncConf or JT's MesaCT tool to create a simple config so you can start LinuxCNC and check if everything is working.
Moderators: PCWjmelson
Time to create page: 0.087 seconds
