Mesa equipment
- Temo
17 Oct 2022 15:17 #254333
by Temo
Mesa equipment was created by Temo
Hello
So I've been trying to get in contact with Mesa pre sales since september 10 this year, but all I get is a confirmation on receiving my request and that my email is forwarded to technical support, I've tried several times, both to Mesanet.com and Mesaus.com but to no avail.
Are there any known email addresses that usually get answered from Mesa?
Terje
Terje
- Thank you received: 5308
17 Oct 2022 15:36 #254335
Replied by PCW on topic Mesa equipment
Specific questions to tech or sales should be answered promptly
General or vague questions may end up in the spam bucket
- Temo
17 Oct 2022 16:36 #254338
by Temo
Replied by Temo on topic Mesa equipment
Haha, that’s a good one, I’ll probably have to buy every card and breakout board associated with RPI4b to try out then, it’s a good sales stunt, haha.
- JT
- Thank you received: 583
17 Oct 2022 22:48 #254371
by JT
Replied by JT on topic Mesa equipment
Hi mesaus.com does not provide email tech support.
JT
JT
- Thank you received: 7462
17 Oct 2022 23:11 #254373
Replied by tommylight on topic Mesa equipment
But
They both provide the best tech support on earth, right here on thins forum!
- JT
18 Oct 2022 17:03 #254436
by JT
JT
And the reason why I don't provide email tech support is I would only be helping one person, discussions on the forum reach a lot of people and help many.But
JT
The following user(s) said Thank You: tommylight, Clive S
- Temo
18 Oct 2022 18:07 #254447
by Temo
Hello JT
Ok I understand, that's fair enough, but maybe you then should have a line or two about that on your website, maybe under where it say: Contact me?
So I sent you a couple of questions, because I'm a noob when it comes to CNC and RPI4b/Mesa cards, but I like the idea of making a setup with a small footprint. This is what I asked when I contacted Mesaus:
Hello
I’m looking at setting up a Raspberry pi 4b with 3-axis LinuxCNC and a Mesa card, but there are so many cards to choose from so I get confused, haha.
I would like a compact setup so I’ve been looking at your 7c80/7c81 card, but I guess I would need another breakout card for my stepper drivers(DM556 or similar) and for my peri pals like bit-setter, touch probe and end stops. I may also use a G540 driver card if it’s very much more easy to set up, but it will be much more costly so I would prefer to start with 3 separate drivers.
What would be your recommended mesa cards for a complete setup including breakout.
Regards
Terje Moe
Thank you
Hello
Regards
Terje Moe
Thank you
- Temo
21 Oct 2022 23:19 #254737
by Temo
Take care
Terje
So I guess the support wasn’t that good, luckily I haven’t bought any Mesa equipment.But
Take care
Terje
- cakeslob
- Thank you received: 280
22 Oct 2022 19:14 #254790
by cakeslob
Linuxcnc can feel overwhelming and frustrating, especially when starting out. So lets tone it down a bit, and read some of the board descriptions.
"7C80 RPI interfaced Step&dir plus I/O interface"
Like the name suggests, it is an RPI interface card with stepper and IO breakout. No extra breakout cards needed to connect your 3 drivers to but the card it not small. the size of card is 8inchs by 4 inches
"7C81 RPI FPGA board" "Three 26 pin header connectors with standard parallel port pinouts and 5V tolerant I/O are provided for compatibility with most parallel port interfaced motion control / CNC breakout cards/ multi axis step motor drives, including Mesa's 25 pin daughtercards. "
This card is similar to the 7c80 but but like the description says, it would need additional breakout boards to connect IO and steppers. This board accepts standard 25pin breakout boards like the chinese bob or the ones supplies from mesa like the 7i76. This board has an overall smaller footprint than the 7c80, with a size of around 4in x 4in.
Replied by cakeslob on topic Mesa equipment
Hello
The following user(s) said Thank You: arvidb, tommylight, Temo
- M4MazakUser
23 Oct 2022 02:17 #254819
by M4MazakUser
Replied by M4MazakUser on topic Mesa equipment
There are pretty good descriptions on the mesa site. Its really up to you as the person doing the build and creating the integration/controller hmi to do a read up and get what you need.
Time to create page: 0.133 seconds
