Share nc_files folder
  • mariusl
  • mariusl's Avatar Topic Author
  • Platinum Member
  • Platinum Member
26 Oct 2022 13:30 #255091 by mariusl
Share nc_files folder was created by mariusl
I recall that one used to be able to share the nc_files folder from the file manager in linux. That seems to not be available anymore. What is the easies way to share the nc_file folder with widows users?
Regards
Marius
www.bluearccnc.com
26 Oct 2022 14:00 #255095 by arvidb
Replied by arvidb on topic Share nc_files folder
The easiest way? Probably using a USB stick.
Otherwise, for true network sharing, you would use samba. If your distro/desktop environment doesn't have built-in support for this, you'd have to set it up manually. See e.g. this .
26 Oct 2022 14:06 #255096 by arvidb
You could also use an ssh client on your Windows machine to transfer files to and from your linux computer, but it wouldn't be "sharing" the folder really, in that your couldn't view it in the Windows file manager or open/edit files in the folder on the Windows computer.
Another option could be sshfs, if you can find a Windows client for it. This might be the easiest solution actually.
  • Moderator
  • Moderator
26 Oct 2022 14:07 #255097 by tommylight
Replied by tommylight on topic Share nc_files folder
It requires installing samba/SMB and an add on for the file manager in use to be able to share directly from the file manager.
This is a bit more complicated, but also deals with file permissions so it is better and safer this way:
community.spiceworks.com/how_to/145928-a...e-share-from-windows
26 Oct 2022 14:07 #255098 by scotth
Replied by scotth on topic Share nc_files folder
I use a Rockstor server on the network and SAMBA to exchange files.
Using Mint 21 helps with the network config.
  • mariusl
  • Platinum Member
  • Platinum Member
26 Oct 2022 14:16 #255099 by mariusl
Replied by mariusl on topic Share nc_files folder
Otherwise, for true network sharing, you would use samba. If your distro/desktop environment doesn't have built-in support for this, you'd have to set it up manually. See e.g. this.
The USB stick doesn't show up when you want to load a nc file under plasmac so I cannot lock the operators out of the linux area. This is very dangerous seeing that they are not computer skilled let alone linux skilled.
Regards
Marius
www.bluearccnc.com
26 Oct 2022 16:28 #255106 by andypugh
Replied by andypugh on topic Share nc_files folder
I use SAMBA (and Avahi / Bonjour) and that means I can save G-code direct from Fusion on the Mac into the nc_files folders of the machine tools.
  • mariusl
  • Platinum Member
  • Platinum Member
26 Oct 2022 16:43 #255109 by mariusl
That is exactly what is need to do. I have been trying all sorts but not being very successful so far. The night is young still.
Regards
Marius
www.bluearccnc.com
26 Oct 2022 16:51 #255112 by andypugh
sudo apt-get install samba
sudo apt-get install avahi-daemon
You _might_ need an smb.conf file, but I have a feeling that Avahi side-steps that.
  • mariusl
  • Platinum Member
  • Platinum Member
26 Oct 2022 17:04 #255113 by mariusl
I have both those installed. And I tried to configure samba via webmin and by setting up the smb.conf file. Samba is a bit of black magic I think.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.391 seconds
