Linux CNC - Mesa Card 7i96s with iHSV57-XX Servo Motor
3 years 8 months ago #265128 by Drillbit
Long time reader first time poster, first time user of LinuxCNC and builder of a milling machine.
Problem: Motor does not rotate.
Motor has for signal Dir -, Dir +, Pul -, Pul +, Ena-, Ena +
Motor has for alarm ALM-, ALM+, PED-, PED+.
Motor has for power VCC, GND
Motor has for changing settings a RS232 port.
I have connected.
VCC to 36V.
GND to ground.
For the pins on the board on TB1/step 0 I connect them to the motor as follows.
0 - GND - not used.
1 - S- to Pul -
2 - S+ to Pul +
3 - D- to Dir -
4 - D+ to Dir +
The RS232 and Alarm functions are not connected. I did connect the RS232 and it came back with valid settings i.e the motor is alive and then disconnected it again.
The Mesa board has 5v and I also connected the earth. The motor has no earth.
The software is able to connect to the board via Ping. 10.10.10.10 and works nicely.
When I move the arrow keys for x,y in LinuxCNC - I can see the ethernet light on the board flicker.
Software.
The config has the MESA 7196s selected and Number 0, X step function selected, 1 to Y and 2 to Z.
LinuxCNC say 2.9.0 and some other items.
Unix has Debian bookworm.
I followed  gnipsel.com/linuxcnc/ for adding in the the realtime kernel - good steps.
Questions:
- What can I check?
- What did I do wrong?
I do not have an oscilliscope.
Want to thank you all so far for being such an amazing resource - i.e I got this far.
3 years 8 months ago #265137 by PCW
Common problems are host latency (causing loss of communication)
and step/dir timing too short.
I would run a latency test and make sure the the initial step timing
exceed the drives minimums
StepTime 5000
StepSpace 5000
DirSetup 20000
DirHold 20000
Are good starting values that work on most drives
Also do no connect the drive ENA pins (these are disable inputs)
3 years 8 months ago #265491 by Drillbit
I redid the wiring and got it turning slowly, so assume my pitch etc. needs setting but can work that out I hope. Thank you.
One more if thats ok.The Mesa 7i96s, has a spindle divider Spindle_out. Do you think it could be safely used with the to "5v_in" the spindle controller - manual attached.
3 years 8 months ago #265507 by PCW
Yes, the 7I96S analog spindle output is designed for potentiometer replacement:
7I96S SPINDLE- --> GND
7I96S SPINDLE OUT --> 5V_IN
7I96S SPINDLE+ --> --5V_OUT
3 years 7 months ago #266216 by Drillbit
Thank you.
Slow replying as one of the motors was bad and it took me ages to figure out.
Will implement the above.
Ok next question if thats ok.
I am just checking the steps on the y axis and with say a 1mm steps + and then the same steps backwards I get something like
0 - 0.99 - 1.99 - 2.98 etc. and then coming back I land on 0.23
I can then go forward again and get 0.99 - 1.99 etc. again.
So it looks like small but consistent backlash. The CNC is a Taige with ball screw.
I assume for the 0.99 I can adjust the steps per rotation.
I have not tuned anything. As the motor has a feedback counter I assume I can fine tune this with the settings in the motor but did not think that I could solve the backlash through motor configuration and that the backlash had to be a hardware fix (how?) or an adjustment in linuxCNC settings (how?)
3 years 7 months ago #266372 by blazini36
You should move a much larger amount than 1mm to calibrate the axis, like 20mm. And you must do so without changing direction or you introduce backlash which is a different problem. So if using a dial indicator move Y+ some amount, then 0 the indicator then move Y+ 20mm. if it did not move exactly 20mm than you adjust the STEP_SCALE in the .ini file or with the "Axis calibration tool". Repeat until you are happy with it.
After getting the STEP_SCALE set properly, then you work on backlash. Move Y+ some amount then with the 0 indicator, move Y- some defined amount, say 1mm. If it did not move 1mm the difference is your backlash. In the ini file under the Y axis add BACKLASH = 0.10 or whatever it was and this will enable backlash compensation for that axis. You should increase STEPGEN_MAXACCEL if using backlash comp.
The following user(s) said Thank You: Drillbit
Time to create page: 0.176 seconds
