Install fun with buster
3 years 6 months ago #269789 by RuddyCrazy
G'Day Guy's,
                    Well I finally got a PCI parallel port card and installed LinuxCNC Buster, on the install it couldn't find the wifi card so it did a minimal install by by that I do mean minuim. This PCI card does come with a driver disk and yes there is a driver for linux but when unpacking it with tar it just kept failing saying the folder wasn't there and came up with the Error 1.
I did start to make the new folders then a mate came around so that was the end of the day, so today more fun trying to get this to see my cnc setup. My old parallel port cnc board just plain worked back in the days of XP and when I reset it up yesterday it came to life like old.
The only way I could get the net as both the ethernet and wifi wouldn't connect was use my smart phone with USB tethering and trying to do a upgrade showed nothing was available symantic package manager wouldn't work either so this is my last day off before my next shift and hopefully I can make some sense out of this.
Cheers Bryan
3 years 6 months ago #269797 by RuddyCrazy
Replied by RuddyCrazy on topic Install fun with buster
G'Day Guy's,
Well had a go this morning at at one time YES the F3 screen came to life and when I toggle the test run for the axis the controller was trying but no movement on any stepper. Now when I toggle my E-Stop it does show up on the screen as off so I do know that pci card is connected. But further tests had the F3 screen blanked out.
The ethernet connection connected to my wifi router played ball and just worked so no problem getting the net and when trying to do apt upgrade it said no packages were released for this distro.
so the fun continues
3 years 6 months ago #269805 by wicki
Replied by wicki on topic Install fun with buster
"when I toggle the test run for the axis the controller was trying but no movement on any stepper."
are you sure, the parport is working?
is there a partport in ?
lspci -nn
3 years 6 months ago - 3 years 6 months ago #269809 by RuddyCrazy
Just went and tried lspci -nn and the response can back with a serial parallel port PCI listing, now this PCI did come with a linux driver but it keeps falling down as shown in this picture. When I first tried it it fell down with no build folder in /dev so I did a mkdir and put a folder in and another link in /lib needed one too.
No it's saying "no rules to make target " and aborts with an error so would I need to do a shell script with make=1 and put it in lib/......./build/ fix the error.
Last edit: 3 years 6 months ago by RuddyCrazy.
3 years 6 months ago #269835 by tommylight
Replied by tommylight on topic Install fun with buster
Normally, there is no need to install drivers for parallel port, it should just work.
Use
sudo lspci -v
To find out the port address, enter that address in StepConf when creating a config, save, run and test the port.
3 years 6 months ago #269860 by wicki
with
grep -i par /proc/ioports
you should see something like this:
0378-037a : parport0
if not:
your pci-card is not a real LPT-parport
Time to create page: 0.058 seconds
