Seeing values of gcode settings
03 May 2023 18:45 #270582 by diep
Seeing values of gcode settings was created by diep
Hello, the active gcodes in the active gcode tab - what do i type in the mdi window or where do i click with mouse to see the value displayed for example of G64 gcode that is active?
Kind Regards,
Vincent
17 May 2023 08:30 #271512 by andypugh
Replied by andypugh on topic Seeing values of gcode settings
I am not sure that there is a built-in way to see the G64 setting.
I have looked at increasingly hacky ways to find it (numbered and named parameters, HAL pins, Python status) and I don't see it mirrored anywhere.
The next step would be to start from the other end and see if the data gets put anywhere in the code, but it is going to be a long and winding journey an I don't have time right now:
github.com/LinuxCNC/linuxcnc/blob/master...erp_convert.cc#L2194
17 May 2023 09:06 - 17 May 2023 09:12 #271516 by Aciera
Replied by Aciera on topic Seeing values of gcode settings
Looks like the G64 settings can be found in the 'settings' attribute in the python interface:
linuxcnc.org/docs/master/html/config/python-interface.html
Not a 'point and click' solution I'm afraid.
Last edit: 17 May 2023 09:12 by Aciera.
17 May 2023 09:15 #271517 by andypugh
And you can run Python in the MDI window (I think...)
(python, print(linuxcnc.status.settings[3])
I would be absolutely astonished if that actually worked, though.
17 May 2023 09:27 - 17 May 2023 09:29 #271518 by rodw
Replied by rodw on topic Seeing values of gcode settings
I thought Andy was right. But wait, there may be a shortcut. But it seems that the G64 P & Q Parameters are passed to the state tags structure
github.com/LinuxCNC/linuxcnc/blob/master...tion/state_tag.h#L96
and
github.com/LinuxCNC/linuxcnc/blob/master...ion/state_tag.h#L118
eg in fields_float[GM_FIELD_FLOAT_PATH_TOLERANCE]
​​​​​​Maybe Andy can tell you if that's accessible from the Python interface, otherwise you would need to add a pin for it in motion.c
github.com/LinuxCNC/linuxcnc/blob/master...motion/motion.c#L708
Good luck!
EDIT: Cross posted, heaps of options!
Last edit: 17 May 2023 09:29 by rodw.
17 May 2023 09:33 #271519 by rodw
So at a guess, the field_float array is copied ot the Python Settings array as the field order is the same
Very cool! Thank Andy for getting state tags into the code base :)
17 May 2023 09:47 - 17 May 2023 09:49 #271521 by Aciera
The magic comment does not work.
'Nested comment found'
It seems that it does not like nested brackets in a comment.
Last edit: 17 May 2023 09:49 by Aciera.
17 May 2023 10:19 #271525 by andypugh
It seems to be
(py, python code)
or
;py, python code
It calls code here:
github.com/LinuxCNC/linuxcnc/blob/2.8/sr...python_plugin.cc#L67
And multi-line python code can (probably) be passed using "\n"L www.programiz.com/python-programming/methods/built-in/exec
Though if the OP wants to do this a lot, a custom M-code might be easier.
17 May 2023 10:46 #271526 by phillc54
Replied by phillc54 on topic Seeing values of gcode settings
If LinuxCNC is started in a terminal the MDI python method does write to terminal but requires a few commands:
;py,import linuxcnc
;py,s=linuxcnc.stat()
;py,s.poll()
;py,print(s.settings[3])
I don't know how to get it to appear in AXIS and I have not tried any other GUI's. I did attempt sending it to stderr but that didn't help.
;py,sys.stderr.write(f"{s.settings[3]}\n")
17 May 2023 11:23 - 17 May 2023 11:29 #271529 by Aciera
Thanks phil,
For output to axis add:
;py,import emccanon
;py,emccanon.MESSAGE(str(s.settings[3]))
Last edit: 17 May 2023 11:29 by Aciera. Reason: use MESSAGE instead of CANON_ERROR
Time to create page: 0.127 seconds
