Debian10 Username and Password
  • Aldenflorio
  • Aldenflorio's Avatar Topic Author
  • Platinum Member
  • Platinum Member
15 Jun 2023 16:06 - 15 Jun 2023 16:43 #273624 by Aldenflorio
after booting screen it just freezes was created by Aldenflorio
I gave this computer to a client a while ago and it has been working well for them up until this point. Every time we boot it up it brings me to the selection menu. After making the selection it freezes on one of two screens
Last edit: 15 Jun 2023 16:43 by Aldenflorio.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
15 Jun 2023 16:30 - 15 Jun 2023 18:28 #273629 by Aldenflorio
Replied by Aldenflorio on topic Debian10 Username and Password
I got it through once, though I let it sit for a bit then starting it again and it has frozen again
Last edit: 15 Jun 2023 18:28 by Aldenflorio.
  • Moderator
  • Moderator
15 Jun 2023 19:22 #273640 by tommylight
Replied by tommylight on topic Debian10 Username and Password
That should be an issue with the DE/File explorer, no idea what XFCE uses for those, and no idea how to fix it.
For Mate, there is a hidden DE settings file that should be deleted and after reboot it works.
Try searching Debian XFCE forums with search terms:
desktop shows with no icons and no task manager
  • Aldenflorio
  • Platinum Member
  • Platinum Member
20 Jun 2023 11:03 - 20 Jun 2023 11:19 #273915 by Aldenflorio
I couldn’t seem to find anything there that approached my issue. I switched computer towers entirely to see if that was the issue and it’s not. It’s not letting me though at all again though. This is a calibrated machine so I don’t want to ruin anything.
I don’t have many options within the boot menu.
they won’t let me into register a profile for the Ubuntu forms because I don’t know what this outputs
date -u +%jXfce|sha256sum|sed 's/\W//g'
this is my start up screen
Last edit: 20 Jun 2023 11:19 by Aldenflorio. Reason: Picture
20 Jun 2023 11:27 #273918 by rodw
Replied by rodw on topic Debian10 Username and Password
Try hitting control-Alt-T
It should open a terminal window
Then try
rm -R ~/.cache/sessions/*
Logout and log in again without rebooting.
Hopefully it's fixed
Ref: askubuntu.com/questions/451847/desktop-i...click-on-the-desktop
I vaguely remember having this happen once years ago.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
20 Jun 2023 11:29 #273919 by Aldenflorio
I got in and I’m leaving it on so it doesn’t freeze again. Though when it freezes at that screen I can’t do anything at all. I can’t even restart it.
since I’m in I can open the terminal and try that
20 Jun 2023 11:35 #273920 by Aciera
Replied by Aciera on topic Debian10 Username and Password
The least you should probably do is backup your machine config folder to some external device, if you haven't already done so.
  • Moderator
  • Moderator
20 Jun 2023 11:38 #273923 by tommylight
Copy the config folder to a USB stick.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
20 Jun 2023 11:42 #273924 by Aldenflorio
Yup I was able to do a backup
  • Aldenflorio
  • Platinum Member
  • Platinum Member
20 Jun 2023 12:01 - 20 Jun 2023 12:06 #273925 by Aldenflorio
I tried what you suggested and it too me to a login page. I’ve never set a password for this and apparently they have not either. I know there’s no default password but it won’t let me log in with nothing added
so I had to reboot and it of course won’t let me into the terminal on boot menu
Last edit: 20 Jun 2023 12:06 by Aldenflorio.
Time to create page: 0.295 seconds
