Problems with USB (Solved)
- JohnnyCNC
- Thank you received: 106
15 Jun 2023 22:09 - 17 Jun 2023 00:16 #273656
by JohnnyCNC
Problems with USB (Solved) was created by JohnnyCNC
Last edit: 17 Jun 2023 00:16 by JohnnyCNC.
- Thank you received: 6928
15 Jun 2023 22:21 #273659
There is Mint 19.3 or Ubuntu 19.04.
Boot the other generic kernel, see if that has issues with USB.
Replied by tommylight on topic Problems with USB (Solved)
There is no such thing as Ubuntu 19.3!!!... This one is running Ubuntu 19.3 and LinuxCNC 2.8.4 with QTDragon.
- JohnnyCNC
16 Jun 2023 00:30 #273664
by JohnnyCNC
Replied by JohnnyCNC on topic Problems with USB (Solved)
I knew I shouldn't have trusted my feeble memory. It is Linux Mint 19.3 Tricia
Linux X3CNC 4.9.0-13-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.228-1 (2020-07-05) x86_64 x86_64 x86_64 GNU/Linux
I'll give that a try Tommy
- JohnnyCNC
16 Jun 2023 02:56 #273675
by JohnnyCNC
I found the USB issue. There was one more connection that I forgot about on a USB extension cord that has a repeater in it. I exercised that connector and the problem is gone.
- Thank you received: 3784
16 Jun 2023 10:00 - 19 Jun 2023 02:32 #273688
Replied by rodw on topic Problems with USB (Solved)
If you are using linuxcnc, please throw versions of Ubuntu and Linux Mint in the bin.
Yeh I know it won't be something you will not like to do but its for the greater good and a functioning machine.
I had to give up Linux mint a few years ago for this greater good.
You will just waste a lot of time for no reason.
The kernels they are based on are too old to have acceptible latency and often will not have drivers for modern hardware.
In many cases the Python version they come with is too old for linuxcnc.
In Ubuntu's case they want you pay for the PREEMPT_RT kernel.
Whereas you can just install the current version of Debian (Version 12 - Bookworm) and type a couple of lines and have a functioning machine with preempt_rt installed.
Type a couple more lines and you can connect Debian 12 to the new Linuxcnc buildbot so you can update at any time byt typing one line.
Do yourself and the world a favour and revert to Debian Bookworm forthwith,
Please refer to this link instead. linuxcnc.org/docs/2.9/html/getting-start...etting-linuxcnc.html
Last edit: 19 Jun 2023 02:32 by rodw.
- Thank you received: 1969
16 Jun 2023 10:49 #273690
Replied by Aciera on topic Problems with USB (Solved)
Rod, the title reads "Problems with debian Bookworm" not problems with mint or ubuntu.
16 Jun 2023 10:57 #273691
The tittle is very wrong, it should be "problems with USB" as pointed at in my first reply to the topic linked here.
The exact issue/reply :
forum.linuxcnc.org/qtvcp/48995-qtdragon-...ues?start=140#273527
16 Jun 2023 19:32 #273713
But Johnny said he was using Mint...... which in my book will never do,,,Rod, the title reads "Problems with debian Bookworm" not problems with mint or ubuntu.
16 Jun 2023 19:41 #273714
Hey, i still use Mint on all but one machine/PC/laptop!
The "not Mint" Acer laptop has Debian BookWorm with 6.1 kernel, works fine, no latency/connection issues, but it is used for testing only so far.
Has issues with keyboard or touchpad, one of those never works, depending on how it feels at boot. When the keyboard goes on strike, it does not work for BIOS also.
- JohnnyCNC
16 Jun 2023 20:56 #273717
by JohnnyCNC
When I first started this thread I was only seeing an issue with bookworm and LCNC 2.9. The Mint and 2.8.4 where fine. But, the issue turned out to be a hardware issue (bad USB) connection that only seem to aggravate Bookworm. As soon as I get 2.9 on Bookworm fully working I'll be switching permanently. I need to get my M6 remap working. After that I think I will be good to commit. I'm also considering upgrading from the BAT1-J1800 + 6i25 + 7i76 to a ODroid H2+ + 7i76E.
Time to create page: 0.162 seconds
