Won’t boot from previously working SSD drive
3 years 4 months ago #273990 by Aldenflorio
I have an ssd drive with a a complete Linuxcnc system on it. I recently took it out of the computer, then set up a bootable usb with another usb that is set to install Linux.
I finished the bootable usd and it works well, so I took the two subs out and put my ssd back in.
now it won’t recognize the ssd and therefore won’t boot from it. I am trying to access boot menu to see if that’s the issue but I can’t access it like normal. I have checked all of the sites in the computer and they seem to be plugged in as normal.
any suggestions?
3 years 4 months ago #273991 by Aldenflorio
3 years 4 months ago #273994 by strahlensauger
Is the ssd reckognized by UEFI?
If not, check your hardware.
If so, you may boot with a USB Linux,
mount and chroot into your SSD Linux and
install and configure grub.
This happens quite often to me, if I remove the Linux SSD
from my main machine.
Windows is no problem, it is so agressivem it always puts itself into nvram...
3 years 4 months ago #273995 by Aldenflorio
How do I do that
3 years 4 months ago #273996 by tommylight
This has nothing to do with UEFI or whatever, the drive is disabled in BIOS, not powered (check connectors are fully seated) or a dead drive.
3 years 4 months ago - 3 years 4 months ago #273998 by Aldenflorio
I believe that the SSD drive is bad though it may be. When I have it plugged into the computer I’m using and I load up my good system I can access it and see that there are files in there. So it’s recognized and holding information at least
and nowwwww, when I boot up my usb drive and log in it goes black then back to the log in screen
Last edit: 3 years 4 months ago by Aldenflorio.
Time to create page: 0.322 seconds
