Starting up linux
3 years 2 months ago #277749 by alfredmaina
Hi there..I am using a 7i96 board  and I when I try to open my base machine  I get an error as attached..changed the address to 10.10.10.10.
..why am I getting this error..any assistance please.
3 years 2 months ago #277750 by tommylight
Replied by tommylight on topic Starting up linux
No attachment
3 years 2 months ago #277913 by alfredmaina
Replied by alfredmaina on topic Starting up linux
Sorry...Here is the image
3 years 2 months ago - 3 years 2 months ago #277917 by JPL
Replied by JPL on topic Starting up linux
This looks like a wrong network configuration,
Make sure that jumpers on your mesa card are in the correct position for ip address 10.10.10.10
Make sure your network card (on your PC) is set according to this: forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards   (or edit  \etc\network\interfaces)
A common mistake is to set the network card (PC) at ip address 10.10.10.10.
Once done you can first type: ping 10.10.10.10   This will tel you if the mesa card could be reached
you can also type: mesaflash --addr 10.10.10.10 --device=ETHER --readhmid Which will provide some info about your mesa card
Last edit: 3 years 2 months ago by JPL.
3 years 2 months ago #277918 by JPL
One more thing:
It is much easier to provide help if we see the whole report file instead of a incomplete picture.
Simply click on 'Create Report File' button (below the text on your picture) and attach the generated file.
3 years 2 months ago #277919 by alfredmaina
Thank you very much...I will try this and give you a response
Time to create page: 0.123 seconds
