7i85s startup question
3 years 1 month ago #280701 by Doug Crews
Hi everyone.  I have a 7i92t+ 7i85s   flashed with 4 pwms.
At power up no operating system no  linuxcnc loaded. Using a dmm I measure 5v across all step/dir    -- pwm / dir pins on each TB for each instance of the differential outputs.
When Linuxcnc loads there is no change.   I enable and the motor takes off at 100%.
It could be a runaway caused by an encoder wiring problem but the 5 volts present  when linuxcnc isn’t loaded sounds an alarm bell for me.
Halshow displays …pwmgen.00.value = 0
Its my first PWM setup so I’ve inevitably done something to cause this.  My gut tells me the  pwm pins should be 0 volts on start up until commanded to move, then show some something between 0-5vdc.
Is there some hardware thing that can be checked?
-Doug
3 years 1 month ago #280702 by PCW
Replied by PCW on topic 7i85s startup question
With a 7I92T you can select pulldown resistors on the output that's connected
to the 7I85S. This should make the non-inverting pins (the /TXN pins) low when
LinuxCNC is not running.
Runaways may still happen because the encoder feedback or PWM direction
may be backwards
3 years 1 month ago #280806 by Doug Crews
Replied by Doug Crews on topic 7i85s startup question
Thanks Peter,  I recall seeing that information in the 7i85 documentation and telling myself to no not forget about it. but I did.   I spent several hours today searching the forum, but I am still hung-up with the PWM. I inverted the output scale and still get a solid 5v across 7i85 TB2 pin 11 &12 on and after power up.  It seems it's supposed to be that way? When I enable the motor is at full speed, and cannot jog at lower speed.
The 7i85 manual mentions using the differential outputs single ended for enables which I plan to explore after I get the PWM under control, but for now I’ve mapped the PWM enable to the analog enable  off a 7i83 board.  This seems to work without problems.
Is there something further that needs to be done with the 7i92t other than flashing it with the appropriate bit file?  I am using pwmgen.XX.output-type 2  Up/down.  Wiring is always a concern,  please see the photo.
3 years 1 month ago #280848 by PCW
OK that cannot work since pins 11 and 12
have the same signal (inverted in one case)
First enable the 7I92T pullup option in the 7I85S connector
Then you would need to use pins 12 and 14 for RPWM and LPWM
and invert the PWM outputs:
setp hm2_7i96s.0.pwmgen.00.out0.invert_output true
setp hm2_7i96s.0.pwmgen.00.out1.invert_output true
3 years 1 month ago #280882 by Doug Crews
I suspected the wiring was the problem and you said earlier I needed to invert.   Thanks for showing it done, and, all the information is in the docs to do this but I’m having a “Deer in the Headlights” moment(s) with this.  could be my avatar...
Here’s where things are at.
7i92t Pullup Voltage jumpers W1 are Up.
7i85s TB2 pins 12 (/TX0,STEP0 ) and 14 (/TX1,DIR0 ) wired to RPWM and LPWM
Power up the motor is now 0 velocity.   But Jogging does nothing or a MDI commanded move does nothing.
PWMgen.00.value = 0  on halshow when jogging.
 I think the pwmgen scale  and duty cycle  works out  if max velocity is 1in/sec.
 The manufacture of the h-bridge says it can handle up to 25kHz PWM.
I can’t help but to think there’s something not connected in the hal file.
File Name: PWMGREP9-15-23.txt
File Size:4 KB
File Name: ROBO_WELD_1.hal
File Size:4.71 KB
File Name: ROBO_WELD_1.ini
File Size:4.02 KB
3 years 1 month ago #280888 by PCW
At the minimum P needs to be something other than 0
or you will get no output
Time to create page: 0.368 seconds
