Run python script automaticly after halui on linuxcnc startup
3 years 1 month ago #280935 by Donno
I have a python script that controls a panel but have to start it manually in terminal on linuxcnc startup, how can this be done automatically after halui is loaded ?
3 years 1 month ago #280937 by zz912
You can set HAL pin of your script in postgui.hal. This can run it.
3 years 1 month ago #280943 by Donno
3 years 1 month ago #280944 by Donno
#SET INI File #    [DISPLAY] #    INCREMENTS = 0.1 mm, .1mm, 10mm #    USER_COMMAND_FILE = axis_hal_jog_speed.py import time import serial import hal import sys import linuxcnc import threading import atexit import os linux_stat_flood = "" linux_stat_spindle_enable = "" linux_stat_spindle_direction = "" linux_axisui_jog_increment = 0 Panel_Value_array = [] HALComponentReady = False time_var = 1 Xjoint_num = 0 Zjoint_num = 2 ser = serial.Serial('/dev/ttyUSB0', 500000, timeout=0.050) s = linuxcnc.stat() c = linuxcnc.command() def my_func():     # Dummy Function     print('Dummy') def LinuxCNCEvent(serial_port):     global h     global s     global linux_stat_flood     global linux_stat_spindle_enable     global linux_stat_spindle_direction     global linux_axisui_jog_increment     global time_var     s.poll()          if not hal.get_value("halui.estop.is-activated") and hal.get_value("halui.machine.on") and not hal.get_value("halui.machine.is-on"):         LinuxSW(0,"EVENT")         time.sleep(0.2)         LinuxSW(1,"EVENT")         time.sleep(0.2)          if linux_axisui_jog_increment != h['Incremental']:         print("Linux_Event Jog_Increment "+str(round(h['Incremental'],1)))         IncCont(round(h['Incremental'],1),"EVENT_UI")                   if linux_stat_flood == "":         linux_stat_flood = hal.get_value("halui.flood.is-on")     else:         if linux_stat_flood != hal.get_value("halui.flood.is-on"):             if hal.get_value("halui.flood.is-on"):                 serial_port.write("SET l_csw 1".encode('utf-8'))             else:                 serial_port.write("SET l_csw 0".encode('utf-8'))                             linux_stat_flood = hal.get_value("halui.flood.is-on")             print("Linux_Event Flood "+str(hal.get_value("halui.flood.is-on")))             time.sleep(time_var)                  if linux_stat_spindle_enable == "" or linux_stat_spindle_direction == "":         linux_stat_spindle_enable = s.spindle[0]["enabled"]         if s.spindle[0]["enabled"] == 0:             linux_stat_spindle_direction = s.spindle[0]["direction"]             serial_port.write("SET l_dir 0".encode('utf-8'))             time.sleep(time_var)         if s.spindle[0]["enabled"] == 1:             linux_stat_spindle_direction = s.spindle[0]["direction"]             if s.spindle[0]["direction"] == -1:                 serial_port.write("SET l_dir 2".encode('utf-8'))                                 time.sleep(time_var)             if s.spindle[0]["direction"] == 1:                 serial_port.write("SET l_dir 1".encode('utf-8'))                                  time.sleep(time_var)                       print("LinuxCNC_Event SPINDLE_ENABLE "+str(s.spindle[0]["enabled"]) )         print("LinuxCNC_Event SPINDLE_DIRECTION "+str(s.spindle[0]["direction"]))     else:         if linux_stat_spindle_enable != s.spindle[0]["enabled"] or linux_stat_spindle_direction != s.spindle[0]["direction"]:             linux_stat_spindle_enable = s.spindle[0]["enabled"]             if s.spindle[0]["enabled"] == 0:                 linux_stat_spindle_direction = s.spindle[0]["direction"]                 serial_port.write("SET l_dir 0".encode('utf-8'))                 time.sleep(time_var)             if s.spindle[0]["enabled"] == 1:                 linux_stat_spindle_direction = s.spindle[0]["direction"]                 if s.spindle[0]["direction"] == -1:                     serial_port.write("SET l_dir 2".encode('utf-8'))                                     time.sleep(time_var)                 if s.spindle[0]["direction"] == 1:                     serial_port.write("SET l_dir 1".encode('utf-8'))                                      time.sleep(time_var)                           print("LinuxCNC_Event SPINDLE_ENABLE "+str(s.spindle[0]["enabled"]) )             print("LinuxCNC_Event SPINDLE_DIRECTION "+str(s.spindle[0]["direction"])) def LinuxSW(Value = 0,State = "INIT"):     global h     if State == "INIT":         print('-',end="")         h.newpin("LinuxSW",hal.HAL_BIT,hal.HAL_IN)         h.newpin("LinuxSW_NOT",hal.HAL_BIT,hal.HAL_IN)     if State == "EVENT":         h["LinuxSW"] = Value         h["LinuxSW_NOT"] = not Value     if State == "SET":         h["LinuxSW"] = Value         h["LinuxSW_NOT"] = not Value         #net ConnectPowerON  halui.machine.on => DonnoPanel.LinuxSW         hal.new_sig("ConnectPowerON",hal.HAL_BIT)         hal.connect('DonnoPanel.LinuxSW',"ConnectPowerON")         hal.connect('halui.machine.on',"ConnectPowerON")         #net ConnectPowerOFF  halui.machine.off => DonnoPanel.LinuxSW_NOT         hal.new_sig("ConnectPowerOFF",hal.HAL_BIT)         hal.connect('DonnoPanel.LinuxSW_NOT',"ConnectPowerOFF")            hal.connect('halui.machine.off',"ConnectPowerOFF")                  print('-',end="") def MH1(Value = 0,State = "INIT"):     global c     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 1:                 print('Event MH1')             os.system ("axis-remote /home/donno/linuxcnc/nc_files/MH1.ngc")     if State == "SET":         print('-',end="")      def MH2(Value = 0,State = "INIT"):     global c     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 1:                 print('Event MH2')             os.system ("axis-remote /home/donno/linuxcnc/nc_files/MH2.ngc")     if State == "SET":         print('-',end="")             def FH1(Value = 0,State = "INIT"):     global c     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 1:                 print('Event FH1')             os.system ("axis-remote /home/donno/linuxcnc/nc_files/FH1.ngc")     if State == "SET":         print('-',end="")             def FH2(Value = 0,State = "INIT"):     global c     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 1:                 print('Event FH2')             os.system ("axis-remote /home/donno/linuxcnc/nc_files/FH2.ngc")     if State == "SET":         print('-',end="")   def IncCont(Value = 0,State = "INIT"):     Value = float(Value)     global Panel_Value_array     global linux_axisui_jog_increment     global c     global time_var     global ser     if State == "INIT":         print('-',end="")         h.newpin("Incremental",hal.HAL_FLOAT,hal.HAL_IN)         h.newpin("Incremental-menu-value",hal.HAL_U32,hal.HAL_IN)         h.newpin("Incremental-menu-set",hal.HAL_BIT, hal.HAL_IN)         h.newpin("Feed_scale",hal.HAL_FLOAT,hal.HAL_IN)         h.newpin("Rapid_scale",hal.HAL_FLOAT,hal.HAL_IN)         h.newpin("SpindleOver_scale",hal.HAL_FLOAT,hal.HAL_IN)         h.newpin("MaxVel_scale",hal.HAL_FLOAT,hal.HAL_IN)         h.newpin("JogSpeed",hal.HAL_FLOAT,hal.HAL_IN)     if State == "EVENT_UI":         for index, item in enumerate(Panel_Value_array):             if Panel_Value_array[index][0] == "IncCont":                 if Value == 0:                     ser.write("SET l_inc 1".encode('utf-8'))                     Panel_Value_array[index][2] = Panel_Value_array[index][1]                     Panel_Value_array[index][1] = 0                     h['Incremental'] = Panel_Value_array[index][1]                     linux_axisui_jog_increment = h['Incremental']                     time.sleep(time_var)                       print('Continua all off')                                 elif Value == 0.1:                     ser.write("SET l_p1 1".encode('utf-8'))                     Panel_Value_array[index][2] = Panel_Value_array[index][1]                     Panel_Value_array[index][1] = 0.1                     h['Incremental'] = 0.1                     linux_axisui_jog_increment = h['Incremental']                     time.sleep(time_var)                     print('Increment 0.1')                                 elif Value == 1:                     ser.write("SET l_1p 1".encode('utf-8'))                     Panel_Value_array[index][2] = float(Panel_Value_array[index][1])                     Panel_Value_array[index][1] = float(1)                     h['Incremental'] = 1                     linux_axisui_jog_increment = h['Incremental']                     time.sleep(time_var)                     print('Increment 1')                                 elif Value == 10:                                     ser.write("SET l_10p 1".encode('utf-8'))                     Panel_Value_array[index][2] = Panel_Value_array[index][1]                     Panel_Value_array[index][1] = 10                     h['Incremental'] = 10                     linux_axisui_jog_increment = h['Incremental']                     time.sleep(time_var)                     print('Increment 10')                                print('IncCont event_ui '+str(Panel_Value_array[index][1]))                      if State == "EVENT":         for index, item in enumerate(Panel_Value_array):             if Panel_Value_array[index][0] == "IncCont":                 if Value == 1 and Panel_Value_array[index][1] > 0:                     h['Incremental-menu-value'] = 0                     h['Incremental-menu-set'] = 1                     print('Continua all off')                 elif Value == 1 and Panel_Value_array[index][1] == 0:                     if Panel_Value_array[index][2] == 0.1:                         h['Incremental-menu-value'] = 1                         h['Incremental-menu-set'] = 1                     if Panel_Value_array[index][2] == 1:                         h['Incremental-menu-value'] = 2                         h['Incremental-menu-set'] = 1                     if Panel_Value_array[index][2] == 10:                         h['Incremental-menu-value'] = 3                         h['Incremental-menu-set'] = 1                     print('Increment previos setting which = '+str(Panel_Value_array[index][2]))                 elif Value == 10:                     h['Incremental-menu-value'] = 1                     h['Incremental-menu-set'] = 1                     print('Increment 0.1')                 elif Value == 100:                     h['Incremental-menu-value'] = 2                     h['Incremental-menu-set'] = 1                     print('Increment 1')                 elif Value == 1000:                     h['Incremental-menu-value'] = 3                     h['Incremental-menu-set'] = 1                     print('Increment 10')                 print('IncCont event '+str(Panel_Value_array[index][1]))                      if State == "SET":         #net IncrementalSelection  axisui.jog.increment => DonnoPanel.Incremental         hal.new_sig("IncrementalSelection",hal.HAL_FLOAT)         hal.connect('DonnoPanel.Incremental',"IncrementalSelection")         hal.connect('axisui.jog.increment',"IncrementalSelection")         #Trigger Event to change menu         hal.new_sig("IncrementalSelectionMenu",hal.HAL_BIT)         hal.connect('DonnoPanel.Incremental-menu-set',"IncrementalSelectionMenu")         hal.connect('axisui.jog.increment-menu.set',"IncrementalSelectionMenu")         #Value to change menu         hal.new_sig("IncrementalMenuValue",hal.HAL_U32)         hal.connect('DonnoPanel.Incremental-menu-value',"IncrementalMenuValue")         hal.connect('axisui.jog.increment-menu.value',"IncrementalMenuValue")             #Feed Scale         hal.new_sig("FeedScaleSignal",hal.HAL_FLOAT)         hal.connect('DonnoPanel.Feed_scale',"FeedScaleSignal")         hal.connect('halui.feed-override.scale',"FeedScaleSignal")         #Rapid_scale         hal.new_sig("RapidScaleSignal",hal.HAL_FLOAT)         hal.connect('DonnoPanel.Rapid_scale',"RapidScaleSignal")         hal.connect('halui.rapid-override.scale',"RapidScaleSignal")           #SpindleOver_scale         hal.new_sig("SpindleOverScaleSignal",hal.HAL_FLOAT)         hal.connect('DonnoPanel.SpindleOver_scale',"SpindleOverScaleSignal")         hal.connect('halui.spindle.0.override.scale',"SpindleOverScaleSignal")         #MaxVel_scale         hal.new_sig("MaxVelScaleSignal",hal.HAL_FLOAT)         hal.connect('DonnoPanel.MaxVel_scale',"MaxVelScaleSignal")         hal.connect('halui.max-velocity.scale',"MaxVelScaleSignal")                  #JogSpeed         hal.new_sig("JogSpeedSignal",hal.HAL_FLOAT)         hal.connect('DonnoPanel.JogSpeed',"JogSpeedSignal")         hal.connect('axisui.jog.speed',"JogSpeedSignal")           for index, item in enumerate(Panel_Value_array):             if Panel_Value_array[index][0] == "IncCont":                 ser.write("SET l_inc 1".encode('utf-8'))                 Panel_Value_array[index][1] = float(0)                 Panel_Value_array[index][2] = float(1)                 h['Inremental'] = float(0)                 linux_axisui_jog_increment = 0                 time.sleep(time_var)                 print('-',end="")                                   def IP1(Value = 0,State = "INIT"):     Value = int(Value)     global Panel_Value_array     global time_var     global ser         if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 1:             print('Event p1')             IncCont(10,"EVENT")     if State == "SET":         print('-',end="")                  def I1P(Value = 0,State = "INIT"):     Value = int(Value)     global Panel_Value_array     global time_var     global ser          if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 1:             print('Event 1p')             IncCont(100,"EVENT")     if State == "SET":         print('-',end="") def I10P(Value = 0,State = "INIT"):     Value = int(Value)     global Panel_Value_array     global time_var     global ser          if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 1:                 print('Event p10')             IncCont(1000,"EVENT")     if State == "SET":         print('-',end="") def PX(Value = 0,State = "INIT"):     global c     global s     global Xjoint_num     global Panel_Value_array     if State == "INIT":         print('-',end="")     if State == "EVENT":         for index, item in enumerate(Panel_Value_array):             if Panel_Value_array[index][0] == "IncCont":                     if Value == 1:                     if Panel_Value_array[index][1] == 0:                         SpeedSec = hal.get_value("axisui.jog.speed")/60                         print(str(hal.get_value("axisui.jog.speed"))+"mm/min : "+str(SpeedSec)+"mm/sec")                         c.jog(linuxcnc.JOG_CONTINUOUS,False,Xjoint_num,SpeedSec)                         print('Event PX GO')                                        if Value == 0:                     if Panel_Value_array[index][1] == 0:                         c.jog(linuxcnc.JOG_STOP, False, Xjoint_num)                         print('Event PX GO STOP')                     else:                         SpeedSec = hal.get_value("axisui.jog.speed")/60                         print(str(hal.get_value("axisui.jog.speed"))+"mm/min : "+str(SpeedSec)+"mm/sec")                         c.jog(linuxcnc.JOG_INCREMENT,False,Xjoint_num,SpeedSec,Panel_Value_array[index][1])                         print('Event PX I'+str(Panel_Value_array[index][1]))                                      if State == "SET":         print('-',end="") def MX(Value = 0,State = "INIT"):     global c     global s     global Xjoint_num     global Panel_Value_array     if State == "INIT":         print('-',end="")     if State == "EVENT":         for index, item in enumerate(Panel_Value_array):             if Panel_Value_array[index][0] == "IncCont":                     if Value == 1:                     if Panel_Value_array[index][1] == 0:                         SpeedSec = hal.get_value("axisui.jog.speed")/60 * -1                         print(str(hal.get_value("axisui.jog.speed"))+"mm/min : "+str(SpeedSec)+"mm/sec")                         c.jog(linuxcnc.JOG_CONTINUOUS,False,Xjoint_num,SpeedSec)                         print('Event MX GO')                                        if Value == 0:                     if Panel_Value_array[index][1] == 0:                         c.jog(linuxcnc.JOG_STOP, False, Xjoint_num)                         print('Event PX GO STOP')                     else:                         SpeedSec = hal.get_value("axisui.jog.speed")/60                         print(str(hal.get_value("axisui.jog.speed"))+"mm/min : "+str(SpeedSec)+"mm/sec")                         c.jog(linuxcnc.JOG_INCREMENT,False,Xjoint_num,SpeedSec,Panel_Value_array[index][1]*-1)                         print('Event MX I'+str(Panel_Value_array[index][1]))                                      if State == "SET":         print('-',end="") def PZ(Value = 0,State = "INIT"):     global c     global s     global Zjoint_num     global Panel_Value_array     if State == "INIT":         print('-',end="")     if State == "EVENT":         for index, item in enumerate(Panel_Value_array):             if Panel_Value_array[index][0] == "IncCont":                     if Value == 1:                     if Panel_Value_array[index][1] == 0:                         SpeedSec = hal.get_value("axisui.jog.speed")/60                         print(str(hal.get_value("axisui.jog.speed"))+"mm/min : "+str(SpeedSec)+"mm/sec")                         c.jog(linuxcnc.JOG_CONTINUOUS,False,Zjoint_num,SpeedSec)                         print('Event PZ GO')                                        if Value == 0:                     if Panel_Value_array[index][1] == 0:                         c.jog(linuxcnc.JOG_STOP, False, Zjoint_num)                         print('Event PZ GO STOP')                     else:                         SpeedSec = hal.get_value("axisui.jog.speed")/60                         print(str(hal.get_value("axisui.jog.speed"))+"mm/min : "+str(SpeedSec)+"mm/sec")                         c.jog(linuxcnc.JOG_INCREMENT,False,Zjoint_num,SpeedSec,Panel_Value_array[index][1])                         print('Event PZ I'+str(Panel_Value_array[index][1]))                                      if State == "SET":         print('-',end="") def MZ(Value = 0,State = "INIT"):     global c     global s     global Zjoint_num     global Panel_Value_array     if State == "INIT":         print('-',end="")     if State == "EVENT":         for index, item in enumerate(Panel_Value_array):             if Panel_Value_array[index][0] == "IncCont":                     if Value == 1:                     if Panel_Value_array[index][1] == 0:                         SpeedSec = hal.get_value("axisui.jog.speed")/60 * -1                         print(str(hal.get_value("axisui.jog.speed"))+"mm/min : "+str(SpeedSec)+"mm/sec")                         c.jog(linuxcnc.JOG_CONTINUOUS,False,Zjoint_num,SpeedSec)                         print('Event MZ GO')                                        if Value == 0:                     if Panel_Value_array[index][1] == 0:                         c.jog(linuxcnc.JOG_STOP, False, Zjoint_num)                         print('Event PZ GO STOP')                     else:                         SpeedSec = hal.get_value("axisui.jog.speed")/60                         print(str(hal.get_value("axisui.jog.speed"))+"mm/min : "+str(SpeedSec)+"mm/sec")                         c.jog(linuxcnc.JOG_INCREMENT,False,Zjoint_num,SpeedSec,Panel_Value_array[index][1]*-1)                         print('Event MZ I'+str(Panel_Value_array[index][1]))                                      if State == "SET":         print('-',end="") def Home(Value = 0,State = "INIT"):     global c     global s     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 0:             print(str(s.joints))             for i in range(s.joints-1,-1,-1):                 print("Home Joint" + str(i),end="")                 c.home(i)                 while not hal.get_value("halui.joint."+str(i)+".is-homed"):                     if hal.get_value("axisui.error") == 1:                         print('Event HOME ABORT')                         break                     time.sleep(0.5)                 time.sleep(1)                 print("*")             print('Event HOME')     if State == "SET":         print('-',end="") def Play(Value = 0,State = "INIT"):     global c     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 0:             c.mode(linuxcnc.MODE_AUTO)             c.auto(linuxcnc.AUTO_RUN, 0)                if State == "SET":         print('-',end="")          def Step(Value = 0,State = "INIT"):     global c     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 0:             c.auto(linuxcnc.AUTO_STEP)     if State == "SET":         print('-',end="") def Pause(Value = 0,State = "INIT"):     global c     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 0:             if hal.get_value("halui.program.is-running"):                 c.auto(linuxcnc.AUTO_PAUSE)             elif hal.get_value("halui.program.is-paused"):                 c.auto(linuxcnc.AUTO_RESUME)     if State == "SET":         print('-',end="") def Stop(Value = 0,State = "INIT"):     global c     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 0:             c.abort()     if State == "SET":         print('-',end="") def UserDeF0(Value = 0,State = "INIT"):     global c     if State == "INIT":         h.newpin("ERRORCLEAR",hal.HAL_BIT,hal.HAL_IN)         h.newpin("Tool_OK",hal.HAL_BIT,hal.HAL_IN)         print('-',end="")     if State == "EVENT":         if Value == 0:             h['ERRORCLEAR'] = 1             h['Tool_OK'] = 1             time.sleep(0.5)             h['ERRORCLEAR'] = 0             h['Tool_OK'] = 0                  if State == "SET":         print('-',end="")         #ERRORPIN         hal.new_sig("ERRORCLEARSignal",hal.HAL_BIT)         hal.connect('DonnoPanel.ERRORCLEAR',"ERRORCLEARSignal")         hal.connect('axisui.notifications-clear',"ERRORCLEARSignal")           hal.new_sig("Click_Tool_Change_OK",hal.HAL_BIT)         hal.connect('DonnoPanel.Tool_OK',"Click_Tool_Change_OK")         hal.connect('hal_manualtoolchange.change_button',"Click_Tool_Change_OK")          def Xaxis(Value = 0,State = "INIT"):     global c     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 0:             c.mode(linuxcnc.MODE_MDI)             c.mdi("G92 X0")             c.mode(linuxcnc.MODE_MANUAL)     if State == "SET":         print('-',end="")          def Zaxis(Value = 0,State = "INIT"):     global c     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 0:             c.mode(linuxcnc.MODE_MDI)             c.mdi("G92 Z0")             c.mode(linuxcnc.MODE_MANUAL)     if State == "SET":         print('-',end="")          def FeedP(Value = 0,State = "INIT"):     global c     global h     if State == "INIT":         h.newpin("Feed_Positive",hal.HAL_BIT,hal.HAL_IN)         print('-',end="")     if State == "EVENT":         if Value == 0:             for index, item in enumerate(Panel_Value_array):                 if Panel_Value_array[index][0] == "IncCont":                         if Panel_Value_array[index][1] == 0.1:                             h['Feed_scale'] = 0.01                             h['Feed_Positive'] = 1                             time.sleep(0.5)                             h['Feed_Positive'] = 0                                                     if Panel_Value_array[index][1] == 1:                             h['Feed_scale'] = 0.1                             h['Feed_Positive'] = 1                             time.sleep(0.5)                             h['Feed_Positive'] = 0                                                  if Panel_Value_array[index][1] == 10:                             h['Feed_scale'] = 1                             h['Feed_Positive'] = 1                             time.sleep(0.5)                             h['Feed_Positive'] = 0                                                   if State == "SET":         print('-',end="")         #Feed Scale         hal.new_sig("FeedP",hal.HAL_BIT)         hal.connect('DonnoPanel.Feed_Positive',"FeedP")         hal.connect('halui.feed-override.increase',"FeedP")            def FeedM(Value = 0,State = "INIT"):     global c     global h     if State == "INIT":         h.newpin("Feed_Negative",hal.HAL_BIT,hal.HAL_IN)         print('-',end="")     if State == "EVENT":         if Value == 0:             for index, item in enumerate(Panel_Value_array):                 if Panel_Value_array[index][0] == "IncCont":                         if Panel_Value_array[index][1] == 0.1:                             h['Feed_scale'] = 0.01                             h['Feed_Negative'] = 1                             time.sleep(0.5)                             h['Feed_Negative'] = 0                                                     if Panel_Value_array[index][1] == 1:                             h['Feed_scale'] = 0.1                             h['Feed_Negative'] = 1                             time.sleep(0.5)                             h['Feed_Negative'] = 0                                                  if Panel_Value_array[index][1] == 10:                             h['Feed_scale'] = 1                             h['Feed_Negative'] = 1                             time.sleep(0.5)                             h['Feed_Negative'] = 0                                                   if State == "SET":         print('-',end="")         #Feed Scale         hal.new_sig("FeedN",hal.HAL_BIT)         hal.connect('DonnoPanel.Feed_Negative',"FeedN")         hal.connect('halui.feed-override.decrease',"FeedN")                def RapidP(Value = 0,State = "INIT"):     global c     global h     if State == "INIT":         h.newpin("Rapid_Positive",hal.HAL_BIT,hal.HAL_IN)         print('-',end="")     if State == "EVENT":         if Value == 0:             for index, item in enumerate(Panel_Value_array):                 if Panel_Value_array[index][0] == "IncCont":                         if Panel_Value_array[index][1] == 0.1:                             h['Rapid_scale'] = 0.01                             h['Rapid_Positive'] = 1                             time.sleep(0.5)                             h['Rapid_Positive'] = 0                                                     if Panel_Value_array[index][1] == 1:                             h['Rapid_scale'] = 0.1                             h['Rapid_Positive'] = 1                             time.sleep(0.5)                             h['Rapid_Positive'] = 0                                                  if Panel_Value_array[index][1] == 10:                             h['Rapid_scale'] = 1                             h['Rapid_Positive'] = 1                             time.sleep(0.5)                             h['Rapid_Positive'] = 0                                                   if State == "SET":         print('-',end="")         #Feed Scale         hal.new_sig("RapidP",hal.HAL_BIT)         hal.connect('DonnoPanel.Rapid_Positive',"RapidP")         hal.connect('halui.rapid-override.increase',"RapidP") def RapidM(Value = 0,State = "INIT"):     global c     global h     if State == "INIT":         h.newpin("Rapid_Negative",hal.HAL_BIT,hal.HAL_IN)         print('-',end="")     if State == "EVENT":         if Value == 0:             for index, item in enumerate(Panel_Value_array):                 if Panel_Value_array[index][0] == "IncCont":                         if Panel_Value_array[index][1] == 0.1:                             h['Rapid_scale'] = 0.01                             h['Rapid_Negative'] = 1                             time.sleep(0.5)                             h['Rapid_Negative'] = 0                                                     if Panel_Value_array[index][1] == 1:                             h['Rapid_scale'] = 0.1                             h['Rapid_Negative'] = 1                             time.sleep(0.5)                             h['Rapid_Negative'] = 0                                                  if Panel_Value_array[index][1] == 10:                             h['Rapid_scale'] = 1                             h['Rapid_Negative'] = 1                             time.sleep(0.5)                             h['Rapid_Negative'] = 0                                                   if State == "SET":         print('-',end="")         #Feed Scale         hal.new_sig("RapidN",hal.HAL_BIT)         hal.connect('DonnoPanel.Rapid_Negative',"RapidN")         hal.connect('halui.rapid-override.decrease',"RapidN") def SpindleOverP(Value = 0,State = "INIT"):     global c     global h     if State == "INIT":         h.newpin("SpindleOver_Positive",hal.HAL_BIT,hal.HAL_IN)         print('-',end="")     if State == "EVENT":         if Value == 0:             for index, item in enumerate(Panel_Value_array):                 if Panel_Value_array[index][0] == "IncCont":                         if Panel_Value_array[index][1] == 0.1:                             h['SpindleOver_scale'] = 0.01                             h['SpindleOver_Positive'] = 1                             time.sleep(0.5)                             h['SpindleOver_Positive'] = 0                                                     if Panel_Value_array[index][1] == 1:                             h['SpindleOver_scale'] = 0.1                             h['SpindleOver_Positive'] = 1                             time.sleep(0.5)                             h['SpindleOver_Positive'] = 0                                                  if Panel_Value_array[index][1] == 10:                             h['SpindleOver_scale'] = 1                             h['SpindleOver_Positive'] = 1                             time.sleep(0.5)                             h['SpindleOver_Positive'] = 0                                                   if State == "SET":         print('-',end="")         #Feed Scale         hal.new_sig("SpindleOverP",hal.HAL_BIT)         hal.connect('DonnoPanel.SpindleOver_Positive',"SpindleOverP")         hal.connect('halui.spindle.0.override.increase',"SpindleOverP") def SpindleOverM(Value = 0,State = "INIT"):     global c     global h     if State == "INIT":         h.newpin("SpindleOver_Negative",hal.HAL_BIT,hal.HAL_IN)         print('-',end="")     if State == "EVENT":         if Value == 0:             for index, item in enumerate(Panel_Value_array):                 if Panel_Value_array[index][0] == "IncCont":                         if Panel_Value_array[index][1] == 0.1:                             h['SpindleOver_scale'] = 0.01                             h['SpindleOver_Negative'] = 1                             time.sleep(0.5)                             h['SpindleOver_Negative'] = 0                                                     if Panel_Value_array[index][1] == 1:                             h['SpindleOver_scale'] = 0.1                             h['SpindleOver_Negative'] = 1                             time.sleep(0.5)                             h['SpindleOver_Negative'] = 0                                                  if Panel_Value_array[index][1] == 10:                             h['SpindleOver_scale'] = 1                             h['SpindleOver_Negative'] = 1                             time.sleep(0.5)                             h['SpindleOver_Negative'] = 0                                                   if State == "SET":         print('-',end="")         #Feed Scale         hal.new_sig("SpindleOverN",hal.HAL_BIT)         hal.connect('DonnoPanel.SpindleOver_Negative',"SpindleOverN")         hal.connect('halui.spindle.0.override.decrease',"SpindleOverN") def MaxVelP(Value = 0,State = "INIT"):     global c     global h     if State == "INIT":         h.newpin("MaxVel_Positive",hal.HAL_BIT,hal.HAL_IN)         print('-',end="")     if State == "EVENT":         if Value == 0:             for index, item in enumerate(Panel_Value_array):                 if Panel_Value_array[index][0] == "IncCont":                         if Panel_Value_array[index][1] == 0.1:                             h['MaxVel_scale'] = 1/60                             h['MaxVel_Positive'] = 1                             time.sleep(0.5)                             h['MaxVel_Positive'] = 0                                                     if Panel_Value_array[index][1] == 1:                             h['MaxVel_scale'] = 10/60                             h['MaxVel_Positive'] = 1                             time.sleep(0.5)                             h['MaxVel_Positive'] = 0                                                  if Panel_Value_array[index][1] == 10:                             h['MaxVel_scale'] = 100/60                             h['MaxVel_Positive'] = 1                             time.sleep(0.5)                             h['MaxVel_Positive'] = 0                                                   if State == "SET":         print('-',end="")         #Feed Scale         hal.new_sig("MaxVelP",hal.HAL_BIT)         hal.connect('DonnoPanel.MaxVel_Positive',"MaxVelP")         hal.connect('halui.max-velocity.increase',"MaxVelP") def MaxVelM(Value = 0,State = "INIT"):     global c     global h     if State == "INIT":         h.newpin("MaxVel_Negative",hal.HAL_BIT,hal.HAL_IN)         print('-',end="")     if State == "EVENT":         if Value == 0:             for index, item in enumerate(Panel_Value_array):                 if Panel_Value_array[index][0] == "IncCont":                         if Panel_Value_array[index][1] == 0.1:                             h['MaxVel_scale'] = 1/60                             h['MaxVel_Negative'] = 1                             time.sleep(0.5)                             h['MaxVel_Negative'] = 0                                                     if Panel_Value_array[index][1] == 1:                             h['MaxVel_scale'] = 10/60                             h['MaxVel_Negative'] = 1                             time.sleep(0.5)                             h['MaxVel_Negative'] = 0                                                  if Panel_Value_array[index][1] == 10:                             h['MaxVel_scale'] = 100/60                             h['MaxVel_Negative'] = 1                             time.sleep(0.5)                             h['MaxVel_Negative'] = 0                                                   if State == "SET":         print('-',end="")         #Feed Scale         hal.new_sig("MaxVelN",hal.HAL_BIT)         hal.connect('DonnoPanel.MaxVel_Negative',"MaxVelN")         hal.connect('halui.max-velocity.decrease',"MaxVelN") def JogSpeedP(Value = 0,State = "INIT"):     global c     global h     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 0:             for index, item in enumerate(Panel_Value_array):                 if Panel_Value_array[index][0] == "IncCont":                         if Panel_Value_array[index][1] == 0.1:                             h['JogSpeed'] = h['JogSpeed'] + 1                                                    if Panel_Value_array[index][1] == 1:                             h['JogSpeed'] = h['JogSpeed'] + 10                                                if Panel_Value_array[index][1] == 10:                             h['JogSpeed'] = h['JogSpeed'] + 100                                         if State == "SET":         print('-',end="")   def JogSpeedM(Value = 0,State = "INIT"):     global c     global h     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 0:             for index, item in enumerate(Panel_Value_array):                 if Panel_Value_array[index][0] == "IncCont":                         if Panel_Value_array[index][1] == 0.1:                             h['JogSpeed'] = h['JogSpeed'] - 1                                                    if Panel_Value_array[index][1] == 1:                             h['JogSpeed'] = h['JogSpeed'] - 10                                                if Panel_Value_array[index][1] == 10:                             h['JogSpeed'] = h['JogSpeed'] - 100                                         if State == "SET":         print('-',end="") def CoolSW(Value = 0,State = "INIT"):     global h     if State == "INIT":         print('-',end="")         h.newpin("CoolSW",hal.HAL_BIT,hal.HAL_IN)         h.newpin("CoolSW_NOT",hal.HAL_BIT,hal.HAL_IN)     if State == "EVENT":         if Value == 0:             if hal.get_value("halui.flood.is-on"):                         h["CoolSW"] = 0                 h["CoolSW_NOT"] = 1             else:                 h["CoolSW"] = 1                 h["CoolSW_NOT"] = 0                 if State == "SET":         hal.new_sig("CoolantSW",hal.HAL_BIT)         hal.connect('DonnoPanel.CoolSW',"CoolantSW")         hal.connect('halui.flood.on',"CoolantSW")         #NOT         hal.new_sig("CoolantSW_NOT",hal.HAL_BIT)         hal.connect('DonnoPanel.CoolSW_NOT',"CoolantSW_NOT")            hal.connect('halui.flood.off',"CoolantSW_NOT")                  print('-',end="")         def SpCW(Value = 0,State = "INIT"):     global h     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 0:                   c.spindle(linuxcnc.SPINDLE_FORWARD, 1)              if State == "SET":                 print('-',end="") def SpCCW(Value = 0,State = "INIT"):     global h     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 0:                     c.spindle(linuxcnc.SPINDLE_REVERSE, 1)              if State == "SET":                 print('-',end="") def SpSW(Value = 0,State = "INIT"):     global h     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 0:             if hal.get_value("spindle.0.on"):                 c.spindle(linuxcnc.SPINDLE_OFF)             else:                 c.spindle(linuxcnc.SPINDLE_FORWARD, 1)     if State == "SET":                 print('-',end="") def Spinc(Value = 0,State = "INIT"):     global h     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 0:             c.spindle(linuxcnc.SPINDLE_INCREASE, 0)                        if State == "SET":                 print('-',end="") def Spdec(Value = 0,State = "INIT"):     global h     if State == "INIT":         print('-',end="")     if State == "EVENT":         if Value == 0:             c.spindle(linuxcnc.SPINDLE_DECREASE, 0)                        if State == "SET":                 print('-',end="") def SerialEvent(serial_port,cmd):     global c     global HALComponentReady     global Panel_Value_array     SerialCount = 0     serial_port.write(cmd.encode('utf-8'))     print(cmd,end="")     while 1:         while serial_port.in_waiting:              if cmd  == "ALL":                  line = ser.readline()                  line = line.decode().strip()                  values = line.split('\n')                  Var = values[0].split(' ')                  Panel_Value_array.append(SerialCount)                  Panel_Value_array[SerialCount] = list()                  Panel_Value_array[SerialCount].append(Var[0])                  Panel_Value_array[SerialCount].append(Var[1])                  Panel_Value_array[SerialCount].append(Var[1])                  #Value_array.append(Var[1])                  try:                      my_func = eval(Var[0])                      my_func()                                      except Exception as e:                     print("*", end = "")                         SerialCount = SerialCount + 1                  if SerialCount == 40:                      print("")                      print("SET",end="")                      cmd  = ""                      time.sleep(1)                      h.ready()                      for index, item in enumerate(Panel_Value_array):                          try:                              my_func = eval(Panel_Value_array[index][0]+"("+Panel_Value_array[index][1]+",'SET')")                              my_func()                          except Exception as e:                              print("*", end="")                      HALComponentReady = True                      print(Panel_Value_array)              else:                  data = serial_port.readline().decode('utf-8').replace("\n", "").strip()                  if data.startswith("EVENT"):                      EventData = data.split(' ')                      for index, item in enumerate(Panel_Value_array):                          if Panel_Value_array[index][0] == EventData[1]:                             eval(Panel_Value_array[index][0]+"("+EventData[2]+",'EVENT')")                             print("EVENT" + EventData[1] +":"+EventData[2])                                      if data.startswith("SET"):                      print(data) try:     h = hal.component("DonnoPanel")     thread = threading.Thread(target=SerialEvent, args=(ser,"ALL"))     thread.start()     FirstRun = True     while True:         if HALComponentReady:             if FirstRun == True:                 print('Loading LinuxCNC Event')                 LinuxCNCEvent(ser)                 print('Panel Ready !')                 FirstRun = False             else:                 LinuxCNCEvent(ser)                 #c.jog(linuxcnc.JOG_INCREMENT, 0, 1,100, 100) except hal.error as e:     print("Error working with signal: {}".format(str(e)))     ser.close()     print("Close")
My script
3 years 1 month ago - 3 years 1 month ago #280975 by zz912
I don't know if it will work, but it might.
# Add in postgui.hal #    setp DonnoPanel.ready 1 h = hal.component("DonnoPanel") h.newpin("ready",hal.HAL_BIT,hal.HAL_IN) while not h["ready"] == 1:    time.sleep(0.5) (Here do what you need)
Last edit: 3 years 1 month ago by zz912.
3 years 1 month ago #280976 by cmorley
in your post_gui hal file try:
loadusr python3 myfile.py
The following user(s) said Thank You: Donno
Time to create page: 0.363 seconds
