Run python script automaticly after halui on linuxcnc startup
  • Donno
  • Donno's Avatar Topic Author
  • Premium Member
  • Premium Member
16 Sep 2023 17:17 #280935 by Donno
I have a python script that controls a panel but have to start it manually in terminal on linuxcnc startup, how can this be done automatically after halui is loaded ?
16 Sep 2023 18:06 #280937 by zz912
You can set HAL pin of your script in postgui.hal. This can run it.
  • Donno
  • Premium Member
  • Premium Member
16 Sep 2023 18:49 #280943 by Donno
Example please ?
  • Donno
  • Premium Member
  • Premium Member
16 Sep 2023 18:55 #280944 by Donno
#SET INI File
#    [DISPLAY]
#    INCREMENTS = 0.1 mm, .1mm, 10mm
#    USER_COMMAND_FILE = axis_hal_jog_speed.py
import time
import serial
import hal
import sys
import linuxcnc
import threading
import atexit
import os
linux_stat_flood = ""
linux_stat_spindle_enable = ""
linux_stat_spindle_direction = ""
linux_axisui_jog_increment = 0
Panel_Value_array = []
HALComponentReady = False
time_var = 1
Xjoint_num = 0
Zjoint_num = 2
ser = serial.Serial('/dev/ttyUSB0', 500000, timeout=0.050)
s = linuxcnc.stat()
c = linuxcnc.command()
def my_func():
    # Dummy Function
    print('Dummy')
def LinuxCNCEvent(serial_port):
    global h
    global s
    global linux_stat_flood
    global linux_stat_spindle_enable
    global linux_stat_spindle_direction
    global linux_axisui_jog_increment
    global time_var
    s.poll()
    if not hal.get_value("halui.estop.is-activated") and hal.get_value("halui.machine.on") and not hal.get_value("halui.machine.is-on"):
        LinuxSW(0,"EVENT")
        time.sleep(0.2)
        LinuxSW(1,"EVENT")
        time.sleep(0.2)
    if linux_axisui_jog_increment != h['Incremental']:
        print("Linux_Event Jog_Increment "+str(round(h['Incremental'],1)))
        IncCont(round(h['Incremental'],1),"EVENT_UI")
    if linux_stat_flood == "":
        linux_stat_flood = hal.get_value("halui.flood.is-on")
    else:
        if linux_stat_flood != hal.get_value("halui.flood.is-on"):
            if hal.get_value("halui.flood.is-on"):
                serial_port.write("SET l_csw 1".encode('utf-8'))
            else:
                serial_port.write("SET l_csw 0".encode('utf-8'))
            print("Linux_Event Flood "+str(hal.get_value("halui.flood.is-on")))
            time.sleep(time_var)
    if linux_stat_spindle_enable == "" or linux_stat_spindle_direction == "":
        linux_stat_spindle_enable = s.spindle[0]["enabled"]
        if s.spindle[0]["enabled"] == 0:
            linux_stat_spindle_direction = s.spindle[0]["direction"]
            serial_port.write("SET l_dir 0".encode('utf-8'))
        if s.spindle[0]["enabled"] == 1:
            if s.spindle[0]["direction"] == -1:
                serial_port.write("SET l_dir 2".encode('utf-8'))
            if s.spindle[0]["direction"] == 1:
                serial_port.write("SET l_dir 1".encode('utf-8'))
        print("LinuxCNC_Event SPINDLE_ENABLE "+str(s.spindle[0]["enabled"]) )
        print("LinuxCNC_Event SPINDLE_DIRECTION "+str(s.spindle[0]["direction"]))
    else:
        if linux_stat_spindle_enable != s.spindle[0]["enabled"] or linux_stat_spindle_direction != s.spindle[0]["direction"]:
def LinuxSW(Value = 0,State = "INIT"):
    global h
    if State == "INIT":
        print('-',end="")
        h.newpin("LinuxSW",hal.HAL_BIT,hal.HAL_IN)
        h.newpin("LinuxSW_NOT",hal.HAL_BIT,hal.HAL_IN)
    if State == "EVENT":
        h["LinuxSW"] = Value
        h["LinuxSW_NOT"] = not Value
    if State == "SET":
        #net ConnectPowerON  halui.machine.on => DonnoPanel.LinuxSW
        hal.new_sig("ConnectPowerON",hal.HAL_BIT)
        hal.connect('DonnoPanel.LinuxSW',"ConnectPowerON")
        hal.connect('halui.machine.on',"ConnectPowerON")
        #net ConnectPowerOFF  halui.machine.off => DonnoPanel.LinuxSW_NOT
        hal.new_sig("ConnectPowerOFF",hal.HAL_BIT)
        hal.connect('DonnoPanel.LinuxSW_NOT',"ConnectPowerOFF")
        hal.connect('halui.machine.off',"ConnectPowerOFF")
        print('-',end="")
def MH1(Value = 0,State = "INIT"):
    global c
    if State == "INIT":
        print('-',end="")
        if Value == 1:
            print('Event MH1')
            os.system ("axis-remote /home/donno/linuxcnc/nc_files/MH1.ngc")
    if State == "SET":
        print('-',end="")
def MH2(Value = 0,State = "INIT"):
    global c
    if State == "INIT":
        print('-',end="")
        if Value == 1:
            print('Event MH2')
            os.system ("axis-remote /home/donno/linuxcnc/nc_files/MH2.ngc")
    if State == "SET":
        print('-',end="")
def FH1(Value = 0,State = "INIT"):
    global c
    if State == "INIT":
        print('-',end="")
        if Value == 1:
            print('Event FH1')
            os.system ("axis-remote /home/donno/linuxcnc/nc_files/FH1.ngc")
    if State == "SET":
        print('-',end="")
def FH2(Value = 0,State = "INIT"):
    global c
    if State == "INIT":
        print('-',end="")
        if Value == 1:
            print('Event FH2')
            os.system ("axis-remote /home/donno/linuxcnc/nc_files/FH2.ngc")
    if State == "SET":
        print('-',end="")
def IncCont(Value = 0,State = "INIT"):
    Value = float(Value)
    global Panel_Value_array
    global c
    global time_var
    global ser
    if State == "INIT":
        print('-',end="")
        h.newpin("Incremental",hal.HAL_FLOAT,hal.HAL_IN)
        h.newpin("Incremental-menu-value",hal.HAL_U32,hal.HAL_IN)
        h.newpin("Incremental-menu-set",hal.HAL_BIT, hal.HAL_IN)
        h.newpin("Feed_scale",hal.HAL_FLOAT,hal.HAL_IN)
        h.newpin("Rapid_scale",hal.HAL_FLOAT,hal.HAL_IN)
        h.newpin("SpindleOver_scale",hal.HAL_FLOAT,hal.HAL_IN)
        h.newpin("MaxVel_scale",hal.HAL_FLOAT,hal.HAL_IN)
        h.newpin("JogSpeed",hal.HAL_FLOAT,hal.HAL_IN)
    if State == "EVENT_UI":
        for index, item in enumerate(Panel_Value_array):
            if Panel_Value_array[index][0] == "IncCont":
                if Value == 0:
                    ser.write("SET l_inc 1".encode('utf-8'))
                    Panel_Value_array[index][2] = Panel_Value_array[index][1]
                    Panel_Value_array[index][1] = 0
                    h['Incremental'] = Panel_Value_array[index][1]
                    linux_axisui_jog_increment = h['Incremental']
                    print('Continua all off')
                elif Value == 0.1:
                    ser.write("SET l_p1 1".encode('utf-8'))
                    Panel_Value_array[index][1] = 0.1
                    h['Incremental'] = 0.1
                    print('Increment 0.1')
                elif Value == 1:
                    ser.write("SET l_1p 1".encode('utf-8'))
                    Panel_Value_array[index][2] = float(Panel_Value_array[index][1])
                    Panel_Value_array[index][1] = float(1)
                    h['Incremental'] = 1
                    print('Increment 1')
                elif Value == 10:
                    ser.write("SET l_10p 1".encode('utf-8'))
                    Panel_Value_array[index][1] = 10
                    h['Incremental'] = 10
                    print('Increment 10')
                print('IncCont event_ui '+str(Panel_Value_array[index][1]))
                if Value == 1 and Panel_Value_array[index][1] > 0:
                    h['Incremental-menu-value'] = 0
                    h['Incremental-menu-set'] = 1
                elif Value == 1 and Panel_Value_array[index][1] == 0:
                    if Panel_Value_array[index][2] == 0.1:
                        h['Incremental-menu-value'] = 1
                    if Panel_Value_array[index][2] == 1:
                        h['Incremental-menu-value'] = 2
                    if Panel_Value_array[index][2] == 10:
                        h['Incremental-menu-value'] = 3
                    print('Increment previos setting which = '+str(Panel_Value_array[index][2]))
                elif Value == 10:
                elif Value == 100:
                elif Value == 1000:
                print('IncCont event '+str(Panel_Value_array[index][1]))
    if State == "SET":
        #net IncrementalSelection  axisui.jog.increment => DonnoPanel.Incremental
        hal.new_sig("IncrementalSelection",hal.HAL_FLOAT)
        hal.connect('DonnoPanel.Incremental',"IncrementalSelection")
        hal.connect('axisui.jog.increment',"IncrementalSelection")
        #Trigger Event to change menu
        hal.new_sig("IncrementalSelectionMenu",hal.HAL_BIT)
        hal.connect('DonnoPanel.Incremental-menu-set',"IncrementalSelectionMenu")
        hal.connect('axisui.jog.increment-menu.set',"IncrementalSelectionMenu")
        #Value to change menu
        hal.new_sig("IncrementalMenuValue",hal.HAL_U32)
        hal.connect('DonnoPanel.Incremental-menu-value',"IncrementalMenuValue")
        hal.connect('axisui.jog.increment-menu.value',"IncrementalMenuValue")
        #Feed Scale
        hal.new_sig("FeedScaleSignal",hal.HAL_FLOAT)
        hal.connect('DonnoPanel.Feed_scale',"FeedScaleSignal")
        hal.connect('halui.feed-override.scale',"FeedScaleSignal")
        #Rapid_scale
        hal.new_sig("RapidScaleSignal",hal.HAL_FLOAT)
        hal.connect('DonnoPanel.Rapid_scale',"RapidScaleSignal")
        hal.connect('halui.rapid-override.scale',"RapidScaleSignal")
        #SpindleOver_scale
        hal.new_sig("SpindleOverScaleSignal",hal.HAL_FLOAT)
        hal.connect('DonnoPanel.SpindleOver_scale',"SpindleOverScaleSignal")
        hal.connect('halui.spindle.0.override.scale',"SpindleOverScaleSignal")
        #MaxVel_scale
        hal.new_sig("MaxVelScaleSignal",hal.HAL_FLOAT)
        hal.connect('DonnoPanel.MaxVel_scale',"MaxVelScaleSignal")
        hal.connect('halui.max-velocity.scale',"MaxVelScaleSignal")
        #JogSpeed
        hal.new_sig("JogSpeedSignal",hal.HAL_FLOAT)
        hal.connect('DonnoPanel.JogSpeed',"JogSpeedSignal")
        hal.connect('axisui.jog.speed',"JogSpeedSignal")
                Panel_Value_array[index][1] = float(0)
                Panel_Value_array[index][2] = float(1)
                h['Inremental'] = float(0)
                print('-',end="")
def IP1(Value = 0,State = "INIT"):
    Value = int(Value)
    global time_var
    global ser
    if State == "INIT":
        print('-',end="")
        if Value == 1:
            print('Event p1')
            IncCont(10,"EVENT")
    if State == "SET":
        print('-',end="")
def I1P(Value = 0,State = "INIT"):
    Value = int(Value)
    global time_var
    global ser
    if State == "INIT":
        print('-',end="")
        if Value == 1:
            print('Event 1p')
            IncCont(100,"EVENT")
    if State == "SET":
        print('-',end="")
def I10P(Value = 0,State = "INIT"):
    Value = int(Value)
    global time_var
    global ser
    if State == "INIT":
        print('-',end="")
        if Value == 1:
            print('Event p10')
            IncCont(1000,"EVENT")
    if State == "SET":
        print('-',end="")
def PX(Value = 0,State = "INIT"):
    global c
    global s
    global Xjoint_num
    if State == "INIT":
        print('-',end="")
                if Value == 1:
                    if Panel_Value_array[index][1] == 0:
                        SpeedSec = hal.get_value("axisui.jog.speed")/60
                        print(str(hal.get_value("axisui.jog.speed"))+"mm/min : "+str(SpeedSec)+"mm/sec")
                        c.jog(linuxcnc.JOG_CONTINUOUS,False,Xjoint_num,SpeedSec)
                        print('Event PX GO')
                if Value == 0:
                        c.jog(linuxcnc.JOG_STOP, False, Xjoint_num)
                        print('Event PX GO STOP')
                    else:
                        c.jog(linuxcnc.JOG_INCREMENT,False,Xjoint_num,SpeedSec,Panel_Value_array[index][1])
                        print('Event PX I'+str(Panel_Value_array[index][1]))
    if State == "SET":
        print('-',end="")
def MX(Value = 0,State = "INIT"):
    global c
    global s
    global Xjoint_num
    if State == "INIT":
        print('-',end="")
                if Value == 1:
                        SpeedSec = hal.get_value("axisui.jog.speed")/60 * -1
                        print('Event MX GO')
                if Value == 0:
                    else:
                        c.jog(linuxcnc.JOG_INCREMENT,False,Xjoint_num,SpeedSec,Panel_Value_array[index][1]*-1)
                        print('Event MX I'+str(Panel_Value_array[index][1]))
    if State == "SET":
        print('-',end="")
def PZ(Value = 0,State = "INIT"):
    global c
    global s
    global Zjoint_num
    if State == "INIT":
        print('-',end="")
                if Value == 1:
                        c.jog(linuxcnc.JOG_CONTINUOUS,False,Zjoint_num,SpeedSec)
                        print('Event PZ GO')
                if Value == 0:
                        c.jog(linuxcnc.JOG_STOP, False, Zjoint_num)
                        print('Event PZ GO STOP')
                    else:
                        c.jog(linuxcnc.JOG_INCREMENT,False,Zjoint_num,SpeedSec,Panel_Value_array[index][1])
                        print('Event PZ I'+str(Panel_Value_array[index][1]))
    if State == "SET":
        print('-',end="")
def MZ(Value = 0,State = "INIT"):
    global c
    global s
    global Zjoint_num
    if State == "INIT":
        print('-',end="")
                if Value == 1:
                        print('Event MZ GO')
                if Value == 0:
                    else:
                        c.jog(linuxcnc.JOG_INCREMENT,False,Zjoint_num,SpeedSec,Panel_Value_array[index][1]*-1)
                        print('Event MZ I'+str(Panel_Value_array[index][1]))
    if State == "SET":
        print('-',end="")
def Home(Value = 0,State = "INIT"):
    global c
    global s
    if State == "INIT":
        print('-',end="")
        if Value == 0:
            print(str(s.joints))
            for i in range(s.joints-1,-1,-1):
                print("Home Joint" + str(i),end="")
                c.home(i)
                while not hal.get_value("halui.joint."+str(i)+".is-homed"):
                    if hal.get_value("axisui.error") == 1:
                        print('Event HOME ABORT')
                        break
                    time.sleep(0.5)
                time.sleep(1)
                print("*")
            print('Event HOME')
    if State == "SET":
        print('-',end="")
def Play(Value = 0,State = "INIT"):
    global c
    if State == "INIT":
        print('-',end="")
        if Value == 0:
            c.mode(linuxcnc.MODE_AUTO)
            c.auto(linuxcnc.AUTO_RUN, 0)
    if State == "SET":
        print('-',end="")
def Step(Value = 0,State = "INIT"):
    global c
    if State == "INIT":
        print('-',end="")
        if Value == 0:
            c.auto(linuxcnc.AUTO_STEP)
    if State == "SET":
        print('-',end="")
def Pause(Value = 0,State = "INIT"):
    global c
    if State == "INIT":
        print('-',end="")
        if Value == 0:
            if hal.get_value("halui.program.is-running"):
                c.auto(linuxcnc.AUTO_PAUSE)
            elif hal.get_value("halui.program.is-paused"):
                c.auto(linuxcnc.AUTO_RESUME)
    if State == "SET":
        print('-',end="")
def Stop(Value = 0,State = "INIT"):
    global c
    if State == "INIT":
        print('-',end="")
        if Value == 0:
            c.abort()
    if State == "SET":
        print('-',end="")
def UserDeF0(Value = 0,State = "INIT"):
    global c
    if State == "INIT":
        h.newpin("ERRORCLEAR",hal.HAL_BIT,hal.HAL_IN)
        h.newpin("Tool_OK",hal.HAL_BIT,hal.HAL_IN)
        print('-',end="")
        if Value == 0:
            h['ERRORCLEAR'] = 1
            h['Tool_OK'] = 1
            time.sleep(0.5)
            h['ERRORCLEAR'] = 0
            h['Tool_OK'] = 0
    if State == "SET":
        print('-',end="")
        #ERRORPIN
        hal.new_sig("ERRORCLEARSignal",hal.HAL_BIT)
        hal.connect('DonnoPanel.ERRORCLEAR',"ERRORCLEARSignal")
        hal.connect('axisui.notifications-clear',"ERRORCLEARSignal")
        hal.new_sig("Click_Tool_Change_OK",hal.HAL_BIT)
        hal.connect('DonnoPanel.Tool_OK',"Click_Tool_Change_OK")
        hal.connect('hal_manualtoolchange.change_button',"Click_Tool_Change_OK")
def Xaxis(Value = 0,State = "INIT"):
    global c
    if State == "INIT":
        print('-',end="")
        if Value == 0:
            c.mode(linuxcnc.MODE_MDI)
            c.mdi("G92 X0")
            c.mode(linuxcnc.MODE_MANUAL)
    if State == "SET":
        print('-',end="")
def Zaxis(Value = 0,State = "INIT"):
    global c
    if State == "INIT":
        print('-',end="")
        if Value == 0:
            c.mdi("G92 Z0")
    if State == "SET":
        print('-',end="")
def FeedP(Value = 0,State = "INIT"):
    global c
    global h
    if State == "INIT":
        h.newpin("Feed_Positive",hal.HAL_BIT,hal.HAL_IN)
        print('-',end="")
        if Value == 0:
                        if Panel_Value_array[index][1] == 0.1:
                            h['Feed_scale'] = 0.01
                            h['Feed_Positive'] = 1
                            time.sleep(0.5)
                            h['Feed_Positive'] = 0
                        if Panel_Value_array[index][1] == 1:
                            h['Feed_scale'] = 0.1
                            time.sleep(0.5)
                        if Panel_Value_array[index][1] == 10:
                            h['Feed_scale'] = 1
                            time.sleep(0.5)
    if State == "SET":
        print('-',end="")
        #Feed Scale
        hal.new_sig("FeedP",hal.HAL_BIT)
        hal.connect('DonnoPanel.Feed_Positive',"FeedP")
        hal.connect('halui.feed-override.increase',"FeedP")
def FeedM(Value = 0,State = "INIT"):
    global c
    global h
    if State == "INIT":
        h.newpin("Feed_Negative",hal.HAL_BIT,hal.HAL_IN)
        print('-',end="")
        if Value == 0:
                            h['Feed_Negative'] = 1
                            time.sleep(0.5)
                            h['Feed_Negative'] = 0
                            time.sleep(0.5)
                            h['Feed_scale'] = 1
                            time.sleep(0.5)
    if State == "SET":
        print('-',end="")
        #Feed Scale
        hal.new_sig("FeedN",hal.HAL_BIT)
        hal.connect('DonnoPanel.Feed_Negative',"FeedN")
        hal.connect('halui.feed-override.decrease',"FeedN")
def RapidP(Value = 0,State = "INIT"):
    global c
    global h
    if State == "INIT":
        h.newpin("Rapid_Positive",hal.HAL_BIT,hal.HAL_IN)
        print('-',end="")
        if Value == 0:
                            h['Rapid_scale'] = 0.01
                            h['Rapid_Positive'] = 1
                            time.sleep(0.5)
                            h['Rapid_Positive'] = 0
                            h['Rapid_scale'] = 0.1
                            time.sleep(0.5)
                            h['Rapid_scale'] = 1
                            time.sleep(0.5)
    if State == "SET":
        print('-',end="")
        #Feed Scale
        hal.new_sig("RapidP",hal.HAL_BIT)
        hal.connect('DonnoPanel.Rapid_Positive',"RapidP")
        hal.connect('halui.rapid-override.increase',"RapidP")
def RapidM(Value = 0,State = "INIT"):
    global c
    global h
    if State == "INIT":
        h.newpin("Rapid_Negative",hal.HAL_BIT,hal.HAL_IN)
        print('-',end="")
        if Value == 0:
                            h['Rapid_Negative'] = 1
                            time.sleep(0.5)
                            h['Rapid_Negative'] = 0
                            time.sleep(0.5)
                            time.sleep(0.5)
    if State == "SET":
        print('-',end="")
        #Feed Scale
        hal.new_sig("RapidN",hal.HAL_BIT)
        hal.connect('DonnoPanel.Rapid_Negative',"RapidN")
        hal.connect('halui.rapid-override.decrease',"RapidN")
def SpindleOverP(Value = 0,State = "INIT"):
    global c
    global h
    if State == "INIT":
        h.newpin("SpindleOver_Positive",hal.HAL_BIT,hal.HAL_IN)
        print('-',end="")
        if Value == 0:
                            h['SpindleOver_scale'] = 0.01
                            h['SpindleOver_Positive'] = 1
                            time.sleep(0.5)
                            h['SpindleOver_Positive'] = 0
                            h['SpindleOver_scale'] = 0.1
                            time.sleep(0.5)
                            h['SpindleOver_scale'] = 1
                            time.sleep(0.5)
    if State == "SET":
        print('-',end="")
        #Feed Scale
        hal.new_sig("SpindleOverP",hal.HAL_BIT)
        hal.connect('DonnoPanel.SpindleOver_Positive',"SpindleOverP")
        hal.connect('halui.spindle.0.override.increase',"SpindleOverP")
def SpindleOverM(Value = 0,State = "INIT"):
    global c
    global h
    if State == "INIT":
        h.newpin("SpindleOver_Negative",hal.HAL_BIT,hal.HAL_IN)
        print('-',end="")
        if Value == 0:
                            h['SpindleOver_Negative'] = 1
                            time.sleep(0.5)
                            h['SpindleOver_Negative'] = 0
                            time.sleep(0.5)
                            time.sleep(0.5)
    if State == "SET":
        print('-',end="")
        #Feed Scale
        hal.new_sig("SpindleOverN",hal.HAL_BIT)
        hal.connect('DonnoPanel.SpindleOver_Negative',"SpindleOverN")
        hal.connect('halui.spindle.0.override.decrease',"SpindleOverN")
def MaxVelP(Value = 0,State = "INIT"):
    global c
    global h
    if State == "INIT":
        h.newpin("MaxVel_Positive",hal.HAL_BIT,hal.HAL_IN)
        print('-',end="")
        if Value == 0:
                            h['MaxVel_scale'] = 1/60
                            h['MaxVel_Positive'] = 1
                            time.sleep(0.5)
                            h['MaxVel_Positive'] = 0
                            h['MaxVel_scale'] = 10/60
                            time.sleep(0.5)
                            h['MaxVel_scale'] = 100/60
                            time.sleep(0.5)
    if State == "SET":
        print('-',end="")
        #Feed Scale
        hal.new_sig("MaxVelP",hal.HAL_BIT)
        hal.connect('DonnoPanel.MaxVel_Positive',"MaxVelP")
        hal.connect('halui.max-velocity.increase',"MaxVelP")
def MaxVelM(Value = 0,State = "INIT"):
    global c
    global h
    if State == "INIT":
        h.newpin("MaxVel_Negative",hal.HAL_BIT,hal.HAL_IN)
        print('-',end="")
        if Value == 0:
                            h['MaxVel_Negative'] = 1
                            time.sleep(0.5)
                            h['MaxVel_Negative'] = 0
                            time.sleep(0.5)
                            time.sleep(0.5)
    if State == "SET":
        print('-',end="")
        #Feed Scale
        hal.new_sig("MaxVelN",hal.HAL_BIT)
        hal.connect('DonnoPanel.MaxVel_Negative',"MaxVelN")
        hal.connect('halui.max-velocity.decrease',"MaxVelN")
def JogSpeedP(Value = 0,State = "INIT"):
    global c
    global h
    if State == "INIT":
        print('-',end="")
        if Value == 0:
                            h['JogSpeed'] = h['JogSpeed'] + 1
                            h['JogSpeed'] = h['JogSpeed'] + 10
                            h['JogSpeed'] = h['JogSpeed'] + 100
    if State == "SET":
        print('-',end="")
def JogSpeedM(Value = 0,State = "INIT"):
    global c
    global h
    if State == "INIT":
        print('-',end="")
        if Value == 0:
                            h['JogSpeed'] = h['JogSpeed'] - 1
                            h['JogSpeed'] = h['JogSpeed'] - 10
                            h['JogSpeed'] = h['JogSpeed'] - 100
    if State == "SET":
        print('-',end="")
def CoolSW(Value = 0,State = "INIT"):
    global h
    if State == "INIT":
        print('-',end="")
        h.newpin("CoolSW",hal.HAL_BIT,hal.HAL_IN)
        h.newpin("CoolSW_NOT",hal.HAL_BIT,hal.HAL_IN)
        if Value == 0:
                h["CoolSW"] = 0
                h["CoolSW_NOT"] = 1
            else:
                h["CoolSW"] = 1
                h["CoolSW_NOT"] = 0
    if State == "SET":
        hal.new_sig("CoolantSW",hal.HAL_BIT)
        hal.connect('DonnoPanel.CoolSW',"CoolantSW")
        hal.connect('halui.flood.on',"CoolantSW")
        #NOT
        hal.new_sig("CoolantSW_NOT",hal.HAL_BIT)
        hal.connect('DonnoPanel.CoolSW_NOT',"CoolantSW_NOT")
        hal.connect('halui.flood.off',"CoolantSW_NOT")
        print('-',end="")
def SpCW(Value = 0,State = "INIT"):
    global h
    if State == "INIT":
        print('-',end="")
        if Value == 0:
            c.spindle(linuxcnc.SPINDLE_FORWARD, 1)
    if State == "SET":
        print('-',end="")
def SpCCW(Value = 0,State = "INIT"):
    global h
    if State == "INIT":
        print('-',end="")
        if Value == 0:
            c.spindle(linuxcnc.SPINDLE_REVERSE, 1)
    if State == "SET":
        print('-',end="")
def SpSW(Value = 0,State = "INIT"):
    global h
    if State == "INIT":
        print('-',end="")
        if Value == 0:
            if hal.get_value("spindle.0.on"):
                c.spindle(linuxcnc.SPINDLE_OFF)
            else:
    if State == "SET":
        print('-',end="")
def Spinc(Value = 0,State = "INIT"):
    global h
    if State == "INIT":
        print('-',end="")
        if Value == 0:
            c.spindle(linuxcnc.SPINDLE_INCREASE, 0)
    if State == "SET":
        print('-',end="")
def Spdec(Value = 0,State = "INIT"):
    global h
    if State == "INIT":
        print('-',end="")
        if Value == 0:
            c.spindle(linuxcnc.SPINDLE_DECREASE, 0)
    if State == "SET":
        print('-',end="")
def SerialEvent(serial_port,cmd):
    global c
    global HALComponentReady
    SerialCount = 0
    serial_port.write(cmd.encode('utf-8'))
    print(cmd,end="")
    while 1:
        while serial_port.in_waiting:
             if cmd  == "ALL":
                 line = ser.readline()
                 line = line.decode().strip()
                 values = line.split('\n')
                 Var = values[0].split(' ')
                 Panel_Value_array.append(SerialCount)
                 Panel_Value_array[SerialCount] = list()
                 Panel_Value_array[SerialCount].append(Var[0])
                 Panel_Value_array[SerialCount].append(Var[1])
                 #Value_array.append(Var[1])
                 try:
                     my_func = eval(Var[0])
                     my_func()
                 except Exception as e:
                    print("*", end = "")
                 SerialCount = SerialCount + 1
                 if SerialCount == 40:
                     print("")
                     print("SET",end="")
                     cmd  = ""
                     time.sleep(1)
                     h.ready()
                         try:
                             my_func = eval(Panel_Value_array[index][0]+"("+Panel_Value_array[index][1]+",'SET')")
                             my_func()
                             print("*", end="")
                     HALComponentReady = True
                     print(Panel_Value_array)
             else:
                 data = serial_port.readline().decode('utf-8').replace("\n", "").strip()
                 if data.startswith("EVENT"):
                     EventData = data.split(' ')
                         if Panel_Value_array[index][0] == EventData[1]:
                            eval(Panel_Value_array[index][0]+"("+EventData[2]+",'EVENT')")
                            print("EVENT" + EventData[1] +":"+EventData[2])
                 if data.startswith("SET"):
                     print(data)
try:
    h = hal.component("DonnoPanel")
    thread = threading.Thread(target=SerialEvent, args=(ser,"ALL"))
    thread.start()
    FirstRun = True
    while True:
        if HALComponentReady:
            if FirstRun == True:
                print('Loading LinuxCNC Event')
                LinuxCNCEvent(ser)
                print('Panel Ready !')
                FirstRun = False
            else:
                LinuxCNCEvent(ser)
                #c.jog(linuxcnc.JOG_INCREMENT, 0, 1,100, 100)
except hal.error as e:
    print("Error working with signal: {}".format(str(e)))
    ser.close()
    print("Close")
My script
17 Sep 2023 04:57 - 17 Sep 2023 05:00 #280975 by zz912
I don't know if it will work, but it might.
# Add in postgui.hal
#    setp DonnoPanel.ready 1
h.newpin("ready",hal.HAL_BIT,hal.HAL_IN)
while not h["ready"] == 1:
   time.sleep(0.5)
(Here do what you need)
Last edit: 17 Sep 2023 05:00 by zz912.
17 Sep 2023 05:21 #280976 by cmorley
in your post_gui hal file try:
loadusr python3 myfile.py
The following user(s) said Thank You: Donno
17 Sep 2023 06:06 #280981 by cakeslob
are you running this as an axis usercommand file? I dont know what you are doing but you should still be able to connect to halui pins from a usercommand file
  • Donno
  • Premium Member
  • Premium Member
17 Sep 2023 18:44 - 17 Sep 2023 18:45 #281016 by Donno
I could not use loadusr python3 myfile.py as linuxcnc through error, i think it is because i have delay Functions in my code.
I started linuxcnc and my script in /home/linuxcnc/.config/autostart <- created two desktop entry so it runs on startup
On my code i had to run it in terminal so my exec=xfce4-terminal -e "myfile.py"
I delay script by 10sec so linuxcnc axis gui can load correctly !
Last edit: 17 Sep 2023 18:45 by Donno.
18 Sep 2023 00:17 #281031 by cmorley
you didn't mention the acrual error so it's hard to know why loadusr python3 failed.
If it is because halui was not loaded yet, there is away to test for that.
Anyways glad u figured something out.
Time to create page: 0.137 seconds
