Error: Program Exceeds Machine Maximum
3 years 1 month ago #281214 by akg1904
I am getting an error while trying to run my gcode  where linuxcnc claims that the "gcode exceeds the machine maximum on Z-Axis". It mainly occurs when I give "Tool length Offset(TLO)" for my tool.
But when I run the Gcode ignoring the error it run absolutely fine and gives the output what I intended.
Now, I am confused regarding the TLO and how I should avoid the error above.
Hopefully someone can shed light and show me the proper way.
I have attached my INI and tool.tbl below.
File Name: xyzac-trt_...9-20.ini
File Size:5.87 KB
Regards
Abhishek
3 years 1 month ago - 3 years 1 month ago #281216 by Aciera
if it is displaying the message in a pop up window like this then you can ignore it and try running the code anyway.:
However, if the errors are displayed in the right bottom corner of the axis window then there really is a problem with limits.
Last edit: 3 years 1 month ago by Aciera.
The following user(s) said Thank You: tommylight, akg1904
3 years 1 month ago #281280 by akg1904
Hi Aciera,
Thank You for the reply.
My error is actually the popup error which is shown in 1st picture in your post, thus I was able to run the program forcefully.
But is there anyway I can avoid this popup error?
Regards
Abhishek
3 years 1 month ago - 3 years 1 month ago #281305 by Aciera
Well, you can if you feel comfortable editing 'axis.py', removing all the lines marked in red will remove the buggy limit check.
On a Rip installation (ie if you compiled linuxcnc on your computer) the file to change is:
<your linuxcnc installation folder>/bin/axis
On package installation:
I'm not sure, I'd have to check where that gets installed.
The following user(s) said Thank You: akg1904
3 years 1 month ago #281323 by d2inventory
Which version are you running?
3 years 1 month ago - 3 years 1 month ago #281348 by akg1904
Thank you all for replies.
I am using RIP installed 2.9 version.
So I think I will try Aciera suggestion.
Regards
Abhishek
Last edit: 3 years 1 month ago by akg1904.
Time to create page: 0.452 seconds
