Replacement HB04 pendant is choppy and inconsistent
3 years 1 day ago - 3 years 1 day ago #284187 by bally123
Hi All
For years I have been using an XHC HB04 - it was great other than occasionally refusing to power up.  Eventually this became a failure mode.
I purchased another one recently as a direct replacment, testing it today i find:
1. Occasionally the pendant lost connection error comes up - i have to restart LinuxCNC to reconnect the pendant. have tried different usb ports no improvement.
2. The motion is not smooth - its choppy and inconsistent with pauses in motion.
3. Step button doesnt always function, several presses are required - I can see the led light with every press but it might or might not change the step value.
Before I assume its a pendant issue has anyone got any suggestions?
To be clear my old pendant did not show any of the issues above.
This new one looks very slighty different to the old one - red power button not silver, black wheel not silver. USB dongle  - slightly different shape.
Thanks for any input.
Andy
Last edit: 3 years 1 day ago by bally123.
3 years 1 day ago #284212 by bally123
Update
I checked the output of the pendant using the teminal, thius eliminating my configs and Linuxcnc
What i found was the message
xhc-hb04: connection lost, cleaning up
Is generated randomly but often. As this is the same message you get when the usb is removed and my old pendant worked fine  I am thinking its a fault on the usb device - or something different about this replacement and its interaction with the driver.
Im using linuxcnc v2.8   - I wonder if there have there been any HB04 driver updates that may help?  - or do i just get on and return it to the supplier.
2 years 11 months ago #284500 by Redneck92
I had a simmilar Problem with my XHC wheb I got it a few years back.
Wrote a thread here for my fix.
forum.linuxcnc.org/38-general-linuxcnc-q...usb-stick-fix#225235
Maybe you have the same Problem aswell.
Took me quite some time to figure this out.
2 years 11 months ago #284501 by bally123
Thanks for your input. I did try side loading the usb but didn't help. I also booted another pc on 2.9 and found same issue. I've sent it back now as convinced it's a faulty item.
Time to create page: 0.123 seconds
