Mesa 7i96 + 7i85s PWM VFD Control
2 years 11 months ago #285156 by Redneck92
Hello,
I just came back from a business trip yesterday and I made a little wiring scetch to show how everything is wired.
I only seem to get 5v to the pwm output. I can´t think of any error.
2 years 11 months ago #285158 by PCW
PWM-  should go to GND (7I85S TB1 pin 10)
PWM+ should go to 7I85S pin 11
2 years 11 months ago #285181 by Redneck92
Okay I will try that tomorrow. Thank you in advance
2 years 11 months ago #285515 by Redneck92
Good Day, Sir!
I just gave your tip a try and It didn´t work.
Spindle starts but I can not alter the RPM. It still runs on max rpm. On the pwm port there are still 4.95V.
Is there a way I can program somwhere  else a pwm port on the 7i96 or so?
I don´t realy need quick response pwm thing since I don´t index the spindle or something like that.
Greetings and thank you.
2 years 11 months ago #285518 by PCW
Is 7I85S TB1 pin 11 low (close to 0V) before LinucCNC is running?
(relative to ground = TB1 pin 10, TB1 pin 12 should not be connected to anything)
2 years 10 months ago #288217 by Redneck92
Hello Mister PCW,
I´m sorry that it took me so long but my wife was in the hospital for a few weeks and I could not get to it.
7i85S TB1 Pin 11 is 0 volt when I measure it to TB1 Pin 10 when Linuxcnc is not running.
If I start Linuxcnc it jumps up to 4,90 volts without doing anything but starting Linuxcnc.
When I invert the PWM output with the code line in my hal that you gave me scenario is as follows:
TB1 Pin 11 0 Volts when Linuxcnc is not running.
When I start Linuxcnc and enable the machine it stays at 0 Volts.
When I run an MDI Command like M3 S3000 or any other value, TB1 Pin11 stays at 0 volts.
Time to create page: 0.206 seconds
