Headless/No HMI w/Python module, can stream data or only poll?
2 years 10 months ago #287346 by TheRoslyak
OPC UA fully accomplishes all tasks. It's even possible, without creating a database, to make a variable that will remember readings over time. (Say, 10,000 points per hour). There is also a library for working with Python. You can use it to create your own client.
2 years 10 months ago - 2 years 10 months ago #287348 by TheRoslyak
If you need to create buttons for local use, you need to scan the HAL environment using the rtapi_mutex_get() function. Then, by name or other parameters, find the address of the pin, signal, or parameter you need. This address can be used for a button, for recording in a database, or for displaying on a graph. Perhaps OPC UA history can record data faster than 50 milliseconds, but I haven't tried it.
Last edit: 2 years 10 months ago by TheRoslyak.
Time to create page: 0.174 seconds
