Kinematics for 4th Axis?
08 Dec 2023 13:18 #287529 by CNC_ANDI
Kinematics for 4th Axis? was created by CNC_ANDI
Hello,
can i install kinematics for a only 4th axis machine too?My 4th axis works really well, but it's annoying to have to mill off all the edges first to define an exact center point for the rotation axis.
With the kinematics you could simply clamp the part on the 4th axis in the vice and simply set a corner as the zero point. If the workpiece is now rotated 180 degrees, should the zero point move with it or not?
08 Dec 2023 16:27 #287546 by Aciera
Replied by Aciera on topic Kinematics for 4th Axis?
Couldn't you use a 3d probe to setup a work offset in the center of rotation of your rotary axis before clamping the work piece? Then you could setup all the required work offsets in relation to the center of rotation.
09 Dec 2023 11:25 #287641 by CNC_ANDI
Replied by CNC_ANDI on topic Kinematics for 4th Axis?
Yes i do it like that this time.
But with kinematics it is much easier....
09 Dec 2023 11:47 #287645 by Aciera
Maybe I misunderstand what you mean by 'kinematics' but would the kinematic not also require to know where the rotational axis is in relation to the machine reference point?
09 Dec 2023 12:01 - 09 Dec 2023 13:40 #287646 by CNC_ANDI
yes for sure. but my question is how i can install the kinematics (TCP Mode)..
and did it work with only 4th axis.
Last edit: 09 Dec 2023 13:40 by CNC_ANDI.
09 Dec 2023 15:33 #287676 by Aciera
Ah ok, yes, TCP kinematics also works for a single rotary axis.
You may want to have a look at '/sim/axis/vismach/5axis/dual-table-rotary' for an XYZAB setup. For your setup you could just permanently set the B joint position to zero.
The following user(s) said Thank You: CNC_ANDI
09 Dec 2023 15:55 #287680 by Aciera
As for the question of the 'zero point' moving
In TCP mode the point rotates with the part in Trivial mode it will not. To have the point rotate with the part but remain oriented on the machine axes would require custom code to translate the coordinates according to the rotation.
I'm not sure but 'Dynamic work offsets' or 'Dynamic Fixture offsets' may be of interest.
05 Jun 2026 07:35 #346912 by marq_torque
Replied by marq_torque on topic Kinematics for 4th Axis?
Hello Aceiera,
I'm also trying to achieve similar 4Axis TCP kinematics. I want to use Rotating spindle head and XZ gantry with fixed table. No B or C axis. I tried to compile 5Axiskins by removing C axis values but not accepting compilation. Any help would be appreciated.
05 Jun 2026 18:15 #346924 by Aciera
I would leave the kinematic as is and simply set the unused joint position to zero.
05 Jun 2026 21:12 #346928 by marq_torque
Can you throw some example? Zero in what?
