- Thank you received: 6
Automatic change of lathe tools.
- jarcysgru
- Topic Author
2 years 9 months ago #291273
by jarcysgru
Automatic change of lathe tools. was created by jarcysgru
Witam, chciałbym wykonać automatyczną wymianę narzędzi w tokarce i pytanie czy silnik krokowy głowicy rewolwerowej jest skonfigurowany jako oś dodatkowa?
- pawel77
- Thank you received: 7
2 years 9 months ago #291277
by pawel77
Replied by pawel77 on topic Automatic change of lathe tools.
It is possible as an extra axis, then through remap force stepper to reach certain position for each tool. but dont think it is good solution.
If you have professional revolver tool you should have switches or another way to code each tool position, and un-,locking mechanism then extra axis is not necessary,
Everything can be done via component: unlock the head, rotate until the position, and lock the head.
- jarcysgru
- Topic Author
2 years 9 months ago - 2 years 9 months ago #291281
by jarcysgru
Replied by jarcysgru on topic Automatic change of lathe tools.
This is how the stepper motor is controlled and whether an electronic PCB is needed ?
This is what I don't know, please explain it to me.
Thank you and best regards.
Last edit: 2 years 9 months ago by jarcysgru.
- pawel77
2 years 9 months ago #291282
by pawel77
Can you send pictures of that revolver and motor plates that is rotating it?
Do you have electrical and mechanical documentation of this revolver?
- jarcysgru
- Topic Author
2 years 9 months ago - 2 years 9 months ago #291322
by jarcysgru
Nie mam go jeszcze gotowego, mam tylko silnik krokowy SM 60/86-3008B - 3,1Nm, siłownik pneumatyczny CQ2 50x10 Compact, koła i pasek. Obudowa i koło zmieniacza są w budowie.
Interesuje mnie jak steruje się silnikiem krokowym i jaki sterownik jest potrzebny do sterowania?
Posiadam 2M542
Posiadam 2M542
Time to create page: 0.170 seconds
