Buttons on controlpanel vs. MPG vs. on-screen controls?
2 years 9 months ago #292126 by thomaseg
I've started designing the controlpanel for my build  and i immediately ran into an issue that i think all others also must have in some way. I was hoping to draw inspiration from what others have done or how "professionals do i". My plan was to have the following controls as an physical interface on the controlpanel:
- Overrides: Feed override / spindle override (0% - 120%)
- Jogging: Jog wheel / axis select(XYZAC + spindle) / Multiplier select (x1, X10, x100)
- EStop / reset
- Run / Hold buttons
First issue: I'm using a touch-screen on my panel and i planned using all other functions as on-screen buttons(coolant, etc)... not sure if i'm going to regret this or not? I see that some has a "random" button matrix they later can assign functions to. Do people actually end up using these? Or is it easier to just use the touch screen? It seems like the trend on professional machines is "less buttons", but i'm not sure if this is a good idea?
Second issue: I was planning on using rotary switches for the axis/multiplier select. BUT if i do this, i cannot have the same functionality on-screen or on an MPG. If the physical rotary switch says "X"-axis, then i cannot change that on-screen or on the MPG. The obvious solution to this is to do push-buttons with indication-lights instead of rotary switches. Are there any other ways of doing this that i'm missing? What are "professionals" doing with this issue? What have you guys done?
Third issue: Similar to 2nd issue: I was planning on using simple potentiometers to handle the overrides. But again then it cannot be overriden(or reset) in software or on MPG. Again the only option seems "endless rotary encoders", but i think i'll loose the "feeling" when wanting to go down to 0% and slowly increase since there isn't a "stop" at 0%... So what have others done here?
I don't mind going the extra mile to get a good solution for a problem. I also don't mind paying for getting high quality, so any ideas will be great appreciated...
/Thomas
2 years 9 months ago #292129 by meister
you can overwrite the gui values via potentiometer and vice versa, the potentiometer value is only taken if the value changes.
For the jog values you can check if you are using the right hal signals, there are several (halui/axisui,...) I think it is possible, but sometimes very complicated :)
i'm still trying to find the right combination:
www.youtube.com/shorts/jnna9jJnXfs
2 years 9 months ago #292131 by thomaseg
Wauw, that looks so awesome! I agree with the last comment in the video ;-)
That would be very cool to incorporate...thanks for the input!
/Thomas
2 years 9 months ago #292132 by TimP
1) using momentary buttons with light indication
2) i use rotary switches, of course with this it will not be back driven from touch screen actions, except if you find motorised rotary switches and make them move.
3) maybe there is rotary encoders with course clicks(few per rotation to give more tactile feedback) and then you need to use LEDs for indicating which scale or axis selected
2 years 9 months ago #292140 by spumco
/Thomas
What do you want your MPG to do?  Just incremental jogs? Or an all-in-one thing?
If you just want it to do incremental jogs, there's no conflict.  You select an axis on the MPG, and twiddle the wheel.  Because the jog-incremental signal/pin is different from the jog-continuous signal/pin, you don't have to worry about conflicting command sources.
Have a look in the HAL examples sub-forum and there are a couple of excellent examples of how to set up an MPG - including 4/5 axis.
You can have that, PLUS you can also have continuous-jog buttons (or a joystick) on your main panel.
If you want an all-in-one MPG plus duplicated controls on the operator panel, then a momentary button to select which command source is active would be easy.
As far as how to integrate with on-screen controls via touch or mouse or keyboard... just dont.  Keyboard/mouse jogging is dangerous, and touchscreens provide no tactile feedback that you're on the intended key/button.  You cannot safely jog or control the machine without looking at the screen... and then you're not looking at the machine to see what's going on.  Just my rant, dont mind me.
The following user(s) said Thank You: Cant do this anymore bye all
2 years 8 months ago - 2 years 8 months ago #292215 by thomaseg
Thanks for you replies! I've given it more thought and i've been playing around with the idea of having push-buttons instead of rotary switches, i've ended up with something like this:
On the left(closest to the door of the machine) is my cyclestart/feedhold and above them feed/spindle override. Then the jogwheel with push-button axis selection above and multiplier(x1, x10, x100) on the right of the wheel. Then 4x4 utility buttons and finally estop+estop reset...
I'll have to rethink the use of the pendant...and maybe skip it all together...or make it way smarter than i originally thought since i cannot use rotary switches...
The keyboard placement is stupid, but as a "version 1" it will work. I'll add easy access to USB ports, so plugging in an extra keyboard will be easy if i need to marathon type something down the road...
/Thomas
Last edit: 2 years 8 months ago by thomaseg.
Time to create page: 0.233 seconds
