Facing Error after updating Linuxcnc to 2.9 from 2.7
2 years 8 months ago #294703 by yrsiddhapura
I tried to update Linuxcnc 2.7 wheezy preempt-rt to LinuxCNC 2.9 bookworm preempt-rt and copy old config files to new and try to start but facing error.
2 years 8 months ago #294704 by yrsiddhapura
Due to limitated file upload here i am attaching mine HAL and INI files.
File Name: 7I76e_io_2...2-28.ini
File Size:4.47 KB
File Name: custom_2024-02-28.hal
File Size:2.01 KB
File Name: postgui_call_list.hal
File Size:87 B
File Name: oprator_20...2-28.hal
File Size:8.18 KB
File Name: 7I76e_io_2...2-28.hal
File Size:12.59 KB
2 years 8 months ago #294707 by Mecanix
Everywhere you see axis.0. will need updating e.g. to axis.x.
Your INI file also need updating. For each axis you need:
[AXIS_X] and [JOINT_0]
[AXIS_Y] and [JOINT_1]
[AXIS_Z] and [JOINT_2]
All in all, you've prolly just discovered that you need a whole new set of config that rhyme with 2.9.
The following user(s) said Thank You: yrsiddhapura
2 years 8 months ago - 2 years 8 months ago #294708 by PCW
The reported error is a syntax error in line 21 of custom,hal:
setp axis.0.jog-vel-mode 0
Which looks OK (at least in the supplied file)
 Edit: as Mechanix suggested, this needs to have the axis letter
rather than number.
This should have been done by the conversion
script that automatically converts 2.7 configurations to 2.8+
It would be _much_  easier to identify the error by running LinuxCNC
from the command line and posting the printed text here.
Last edit: 2 years 8 months ago by PCW.
2 years 8 months ago #294712 by yrsiddhapura
Thank you so much guys will try to change axis number to letter and also try conversion script
2 years 8 months ago #294720 by Wieser
A side question from an unexperienced user.
How do I get Linuxcnc to show such an error message when failing at startup? Is it a HAL or INI command?
My current workflow is to change only a single thing in HAL, and then restart linuxcnc.
If I change or add multiple lines I never know what the cause problem is when linuxcnc won't start afterwards.
Time to create page: 0.562 seconds
