Run linuxcnc as root user
- nauman
14 May 2024 07:08 - 14 May 2024 07:14 #300556
by nauman
Run linuxcnc as root user was created by nauman
Hi
I am tryinh to run linuxcnc on fedora using copr.fedorainfracloud.org/coprs/dwrobel/linuxcnc/ link
Now I am trying to run it as root user because I don't want to give root access to main user.
after running linuxcnc command in terminal I am getting
LINUXCNC - 2.10.0-0.100.20231213git6d8161a.fc38
Machine configuration directory is '/usr/share/doc/linuxcnc/examples/sample-configs/sim/axis'
Machine configuration file is 'axis.ini'
Starting LinuxCNC...
linuxcncsvr (261738) emcsvr: machine 'LinuxCNC-HAL-SIM-AXIS' version '1.1'
Refusing to run as root without fallback UID specified
To run under a debugger with I/O, use e.g.,
sudo env RTAPI_UID=`id -u` RTAPI_FIFO_PATH=$HOME/.rtapi_fifo gdb /usr/bin/rtapi_app
<commandline>:0: waitpid failed /usr/bin/rtapi_app tpmod
<commandline>:0: /usr/bin/rtapi_app exited without becoming ready
<commandline>:0: insmod for tpmod failed, returned -1
<commandline>:0: waitpid failed /usr/bin/rtapi_app homemod
<commandline>:0: insmod for homemod failed, returned -1
milltask (261749) task: machine 'LinuxCNC-HAL-SIM-AXIS' version '1.1'
halui (261754) halui: machine 'LinuxCNC-HAL-SIM-AXIS' version '1.1'
Found file(lib): /usr/share/linuxcnc/hallib/core_sim.hal
/usr/share/linuxcnc/hallib/core_sim.hal:5: waitpid failed /usr/bin/rtapi_app trivkins
/usr/share/linuxcnc/hallib/core_sim.hal:5: /usr/bin/rtapi_app exited without becoming ready
/usr/share/linuxcnc/hallib/core_sim.hal:5: insmod for trivkins failed, returned -1
USRMOT: ERROR: command 30 timeout
emcMotionInit: emcTrajInit failed
USRMOT: ERROR: command 3 timeout
LinuxCNC terminated with an error. You can find more information in the log:
/root/linuxcnc_debug.txt
and
/root/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
File: /root/linuxcnc_debug.txt
260460
260470
Stopping realtime threads
Unloading hal components
File: /root/linuxcnc_print.txt
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib64/tcl8.6/linuxcnc2.10.0
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
INIFILE=/usr/share/doc/linuxcnc/examples/sample-configs/sim/axis/axis.ini
VERSION=1.1
PARAMETER_FILE=sim.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins
and
260460
260470
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins
Last edit: 14 May 2024 07:14 by nauman.
- Online
- Thank you received: 7461
14 May 2024 11:12 #300568
In general, do not run anything as root unless strictly required. it is a security risk, although not as terrible as the internet will try to convince you.
There might also be the possibility of running any program as another user in Linux, again, no idea if and how as it's been over 15 years since i did that and a lot has changed.
Replied by tommylight on topic Run linuxcnc as root user
You might be able to run it after setting a fallback UID, but i have no idea how to do that.Refusing to run as root without fallback UID specified
- Thank you received: 426
14 May 2024 19:12 #300593
Replied by Cant do this anymore bye all on topic Run linuxcnc as root user
The biggest issue is the mess that can be made of the file system.
TBH the OP confuses me.
- Thank you received: 5308
14 May 2024 20:15 #300599
Replied by PCW on topic Run linuxcnc as root user
I would think that would lower rather than raise security.
- nauman
14 May 2024 20:22 #300600
by nauman
Replied by nauman on topic Run linuxcnc as root user
I have one root and one non-root user. So the idea is root user is running linuxcnc and non-root user is sending commands via python api. So I have all security issues under control.
- nauman
14 May 2024 20:23 #300601
by nauman
User has no access to file system i have one service running which is doing all the work
- nauman
14 May 2024 20:25 #300602
by nauman
I am taking care of the security. Giving root level access to non-root user is more risky for me.
- Online
14 May 2024 21:11 #300609
Pretty sure something is amiss, and given the wrong info on the internet, i am not surprised at all.
Thinking a bit, did you work with Windows Domain Servers?
Linux does not work like that.
You can set the PC to boot into a normal user, you can limit everything to it, so it can run LinuxCNC and not have access to files at all, but this requires someone with SUDO privileges to open a file. Once only.
Or you can limit access to a single folder so he can open files and run the machine, but not save files or open files on other folders, etc, etc
It is a simple as "do not give the user the password", that is it. In normal use they will never need it.
Why would you give main user root access? There is no need for it, ever if the normal user does not need to install or remove something.Now I am trying to run it as root user because I don't want to give root access to main user.
That is as simple as setting permissions to a single user folder.User has no access to file system i have one service running which is doing all the work
I sincerely doubt it, you do NOT have to give root access to user if you think they do not need it.I am taking care of the security. Giving root level access to non-root user is more risky for me.
15 May 2024 00:20 #300635
With regards to “security” with Linuxcnc.
It really comes down to who has access to the machine. I feel once the “bad guy” has physical access it’s the damage that can be done to the cnc machine whilst running linuxcnc. It’s not like you’re running a server with sensitive info, you’re running a piece of equipment that can either harm personnel or damage itself.
First rule of security is physical security of the machine. Once an unauthorised person get physical access to your cnc machine I can guarantee it’s not the file system on the computer you’ll be “shitting bricks” about.
- Thank you received: 4137
15 May 2024 04:47 #300641
Replied by rodw on topic Run linuxcnc as root user
I might be wrong but from my memory linuxcnc does not like being run by the root user. Certainly compiling hte source as root creats all sorts of issues. I found that out the hard way.
What you could do is build linuxcnc from source via RIP as a specific user and that will place all of the executables in that users home folder. The linuxcnc folder will also be there too. Its pretty easy to do. I did a tutorial of it.
So other users can be set up as another user and they will never see any access to linuxcnc and root is not used at all.
Time to create page: 0.621 seconds
