Gremlin rewrite for OpenGL ES and possible optimization
2 years 4 months ago #303498 by alex_sar
Hi All,
I tried to rewrite Gremlin - make new widget based on existing code and contribute it. It made with using of recent OpenGL ES API (shaders/vertex buffers/etc.). The code is not ready to show yet, but I got all parts working and it is possible to make it handling bigger g-code files and do it fast enough. Currently big files simply excluded from preview. At first look, the problem is large Python trajectory arrays that filled one-by-one and then handled in Python again with lot of iterations. I rewrote it to use number of continous memory buffers (fixed size each) and it made a big change immediately. That is not the question, I hope I can show results soon. Just want to ask if anyone have interest in this new widget?
Another big deal is number of calls between C++ code and Python code. I did not measure it yet, but gcodemodule.cc does calls like this for any point in trajectory:
PyObject *result = callmethod(callback, "straight_feed", "fffffffff", x, y, z, a, b, c, u, v, w); // gcodemodule.cc:340
When it repeated n*thousand times, it becomes a bottleneck for sure. My idea is to modify method
static PyObject *parse_file(PyObject *self, PyObject *args) {
and add an optional parameter for this to accept C method pointers for "straight_feed", "traverse", etc. So when this parameter passed, it will call C callbacks instead of python methods and do not do all this Python variable conversion back and forth.  Something like this
if (straight_feed_callback) {   (*straight_feed_callback)(x, y, z, a, b, c, u, v, w); } else {   PyObject *result =   callmethod(callback, "straight_feed", "fffffffff",   x, y, z, a, b, c, u, v, w);   if(result == NULL) interp_error ++;   Py_XDECREF(result); }
I believe this may be a huge performance win and I hope it does not violate any LinuxCNC development guidelines.
My question is to project maintainers. If I make this change and submit to Github to merge, will it be accepted?
The following user(s) said Thank You: MennilTossFlykune, JT, hmnijp
2 years 4 months ago #303499 by PCW
Not a developer but sounds great especially
for complex gcode or slower machines.
Probably best in a separate branch initially.
2 years 4 months ago #303500 by tommylight
If you do not try, you will never know.
2 years 4 months ago #303506 by alex_sar
2 years 4 months ago #303516 by MennilTossFlykune
I am very interested in seeing it. Is it a drop-in replacement for glcanon.py?
2 years 4 months ago #303537 by alex_sar
Yes, that is the goal.
One thing that is still 100% unclear for me is foam cutter visualization. There is some magic code in Gremlin for this. I never worked with such kind of machines. Is there any LinuxCNC documentation regarding foam cutter setup? Or may be one can explain in short?
Time to create page: 0.072 seconds
