Gremlin rewrite for OpenGL ES and possible optimization
2 years 4 months ago - 2 years 4 months ago #303538 by Aciera
Have a look at the foam simulation config 'configs/sim/axis/foam/axis_foam.ini'.
Basically it produces two separate previews, one for XY and one for UV
[edit]
Note that the Z,W height comes from the gcode lines (there are no actual Z or W axes)
(AXIS,XY_Z_POS,5)
(AXIS,UV_Z_POS,30)
[edit2]
The idea is that the two cones represent the end of a hot wire cutting through styrofoam
Last edit: 2 years 4 months ago by Aciera.
The following user(s) said Thank You: alex_sar
2 years 4 months ago #303543 by alex_sar
Thank you, that is clear now!
3 months 2 days ago #348210 by alex_sar
Hi all! Long time no speak.   Finally, I was able to finish this transition. There is the PR:  github.com/LinuxCNC/linuxcnc/pull/4293 Any feedback is welcome!
The following user(s) said Thank You: tommylight, MX_Master, MennilTossFlykune, onceloved, NWE
Time to create page: 0.058 seconds
